problem with cam bolts??
Old Jul 31, 2009 | 01:30 PM
bigbluejk's Avatar
Originally Posted by jonmorgan12
So my handling in my jeep is very squirrely. When i go over even the smallest bumps the steering wheel is jerked either to the right or left pretty hard..
I was told that putting some cam bolts on would do the trick. But every thread i read about it about how horrible they are. Would i be better off with lower control arms instead? I'm just tired of my jeep handling so poorly. I have a 3.5 inch standard skyjacker lift on 32" tires. I have adj front and rear trackbar relocation bracket as well
Should i replace the front and rear track bar with an adj one to fix this problem? Please help!
so littlejon do you think that i should get an adj front track bar or something to fix my geometry?
do you have a front adjustable track bar, or a front track bar bracket?
Old Jul 31, 2009 | 03:17 PM
mkjeep's Avatar
Squirrleyness or flighty steering can seriously be helped with front adj lowers.measure your axles and see if they are close to being centered and go from there.if they are then get adj lowers and check your toe in.
Old Jul 31, 2009 | 06:30 PM
jonmorgan12's Avatar
i have a front and rear track relocation bracket
Old Jul 31, 2009 | 06:40 PM
wrnglrguy's Avatar
Is the trackbar and the drag link parrallel to eachother? That needs to happen as well as having the caster set correctly for the lift. Those 2 things together "should" fix your problem. If the 2 bars are parallel, then the front lower control arms should do the trick.
Old Jul 31, 2009 | 06:44 PM
Ryanc's Avatar
Take some pictures of your setup also. Try to solve you problem first without possibly making more problems.
Old Jul 31, 2009 | 07:35 PM
JackMac4's Avatar
This is very simple to fix...as has been mentioned, you need to check a number of things. You can help the flightyness by adjusting your caster, but it sounds like your real issue here is bump steer. Your front trackbar relocation bracket is probably not enough to get your trackbar to the correct geometry would be my guess. The fact that its not an adjustable trackbar only contribues to things here...
So I would recommend you start with getting a front adjustable trackbar. Get your axle centered, and if you still experience bump steer - you really need to look at your angles for your trackbar and drag link. If those are good then I would move on to your control arms. If they aren't good (parallel) then you need to consider a different drop pitman arm or a flipped drag link kit to lessen the angle of your drag link to get it back to parallel with your track bar.
Old Jul 31, 2009 | 10:05 PM
nthinuf's Avatar
As a little pro-active advice, browse this thread concerning those trackbar relo brackets.
https://www.jk-forum.com/forums/show...ight=skyjacker
Old Aug 1, 2009 | 07:31 AM
Littlejon's Avatar
Originally Posted by bigbluejk
I disagree. If there is a drop pitman and a track arm bracket used together then track and drag should both be in parallel. unless you are saying you used an udjustable front trackbar and a bracket only in the rear. If that is the case either ditch the pitman arm or add a bracket in the front and littlejon is right.
When he mentions that his steering wheel is jerked over the smallest bumps in the road that tells me that it is a steering geometry angle issue causing bump steer. The flightiness would be fixed some by adding adjustable lowers, but it will not do anything for the bump steer since that is not a castor issue. Just because he has a dropped pitman arm doesn't mean they are in alignment. Even WOL on his EVO set up and a drop pitman arm, and adjustable track bar had to fabricate a track bar bracket to bring them into alignment.
Old Aug 1, 2009 | 08:12 AM
mkjeep's Avatar
And this is why I suggested measuring your axles to see if they were centered. Relocatio brackets often do dot exactly center your axle, that can only be done with adj track bars as mentioned already. Hey you may be lucky and they're centered. key is, find out where your prob lies before just spending money on parts that you may not need.
Old Aug 1, 2009 | 11:25 AM
wayoflife's Avatar
JK-Forum Founder
Yes I do have a drop pitman arm- i just want to make sure that front lower control arms will do the trick before i spend like $400 on them
just to verify, did you make sure to install a track bar relocation bracket at the same time? if not, that is your problem right there.
EDIT, i see that you do have one on. is there a chance that you can take a pic of your front end so that i can see what it looks like?
