problem with ESP/BAS
A few months ago i installed a tf 2,5" coil lift with shocks. The kit goes very nice, except for the front axle. It was a little displaced to the right side. So i decided to install a tf adj. front track bar and a steering stab. shock. I installed two days ago, but yesterday driving to my home the light from the ESP/BAS and the control traction switched on. With the ESP button i can switch off the light for the control traction, but the one for the ESP/BAS continues on. I have recentered the steering wheel. have you any idea how to solve it? is it a steering align problem?
Uge, Hope someone smart replies, I installed teraflex 2 1/2 lift kit just last saturday, drove it about 10miles on sunday with no light,Backed out of the driveway this morning and spun a wheel just a little in the snow on boom Light came on, drove it 4 times in the next few hours and light stayed on. Just backed up in in a hr ago and the dang light went out. Cant explain but it went on one time before for a day before i started doing and mods.
Check the sensor wires on both front wheels and check for rub marks or any signs of it being nicked. My light comes on sometimes bc the wire rubbed the rim and caused it to expose the wire inside. I just put electrical tape over it for now.
use the search option in the upper right of the forum.....but could be any number of things. from loose bolts, to an alignment problem. good luck.
use the ignition key sequence to diagnose any codes......
with the JK OFF turn the key from OFF to ACC ( do not start the JK!!!) 3 times quickly.....your odometer will then scan for ACTIVE not STORED codes.
B1402 - FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1403 - FRONT LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1405 - FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1406 - FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1407 - FRONT RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1409 - REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT LOW
B140A - REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B140B - REAR LEFT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B140D - REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT LOW
B140E - REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B140F - REAR RIGHT AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1420 - AUDIO CASSETTE ERROR/INOPERABLE CASSETTE
B1421 - AUDIO CD READ ERROR/INOPERABLE DISC
B1422 - AUDIO DVD READ ERROR/INOPERABLE DISC
B1423 - VES DVD READ ERROR/INOPERABLE DISC
B1424 - IMPROPER DVD-WRONG REGION
B1429 - RADIO DISPLAY HIGH TEMPERATURE
B142A - RADIO UNIT HIGH TEMPERATURE
B142C - VES VIDEO SCREEN DISCONNECTED
B142D - AUDIO ANTENNA NOT CONNECTED
B142E - GPS ANTENNA NOT CONNECTED
B142F - SATELLITE RADIO ANTENNA NOT CONNECTED
B1430 - SATELLITE RADIO ANTENNA INTERNAL PERFORMANCE
B1460 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
B1461 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1462 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1463 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1464 - CHANNEL 1 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
B1465 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
B1466 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1467 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1468 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1469 - CHANNEL 2 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
B146A - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
B146B - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B146C - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B146D - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B146E - CHANNEL 3 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
B146F - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
B1470 - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1471 - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1472 - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1473 - CHANNEL 4 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
B1474 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
B1475 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B1476 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B1477 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B1478 - CHANNEL 5 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
B1479 - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT PERFORMANCE
B147A - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT LOW
B147B - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT HIGH
B147C - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT OPEN
B147D - CHANNEL 6 AUDIO SPEAKER OUTPUT CIRCUIT SHORTED TOGETHER
B1613 - PANEL ILLUMINATION CONTROL CIRCUIT LOW
B1615 - PANEL ILLUMINATION CONTROL CIRCUIT OPEN
B161A - COURTESY/DOME LAMP CONTROL CIRCUIT
B161E - READING LAMP CONTROL CIRCUIT
B162B - LEFT LOW BEAM CONTROL CIRCUIT LOW
B162C - LT LOW BEAM CONTROL CKT HI
B162F - RIGHT LOW BEAM CONTROL CIRCUIT LOW
B1630 - RIGHT LOW BEAM CONTROL CIRCUIT HIGH
B1633 - LEFT HI BEAM CONTROL CIRCUIT LOW
B1634 - LEFT HI BEAM CONTROL CIRCUIT HIGH
B1637 - RIGHT HI BEAM CONTROL CIRCUIT LOW
B1638 - RIGHT HI BEAM CONTROL CIRCUIT HIGH
B163B - FRONT LEFT TURN CONTROL CIRCUIT LOW
B163C - FRONT LEFT TURN CONTROL CIRCUIT HIGH
B163F - FRONT RIGHT TURN CONTROL CIRCUIT LOW
B1640 - FRONT RIGHT TURN CONTROL CIRCUIT HIGH
B1643 - REAR LEFT TURN CONTROL CIRCUIT LOW
B1644 - REAR LEFT TURN CONTROL CIRCUIT HIGH
B1644 - RIGHT STOP LAMP CONTROL CIRCUIT HIGH
B1647 - REAR RIGHT TURN CONTROL CIRCUIT LOW
B1648 - REAR RIGHT TURN CONTROL CIRCUIT HIGH
B1663 - REAR FOG LAMP CONTROL CIRCUIT LOW
B1664 - REAR FOG LAMP CONTROL CIRCUIT HIGH
B166B - LEFT TRAILER TOW LAMP CONTROL CIRCUIT LOW
B166C - LEFT TRAILER TOW LAMP CONTROL CIRCUIT HIGH
B166F - RIGHT TRAILER TOW LAMP CONTROL CIRCUIT LOW
B1670 - RIGHT TRAILER TOW LAMP CONTROL CIRCUIT HIGH
B16B1 - LEFT STOP LAMP CONTROL CIRCUIT HIGH
B16F8 - FRONT LEFT FOG LAMP CONTROL CIRCUIT LOW
B16F9 - FRONT LEFT FOG LAMP CONTROL CIRCUIT HIGH
B16FC - FRONT RIGHT FOG LAMP CONTROL CIRCUIT LOW
B16FD - FRONT RIGHT FOG LAMP CONTROL CIRCUIT HIGH
B17B8 - LEFT STOP LAMP CONTROL CIRCUIT OVERCURRENT
B17B9 - RIGHT STOP LAMP CONTROL CIRCUIT OVERCURRENT
B17BA - HEADLAMP LEVELING MOTOR CONTROL CIRCUIT OVERCURRENT
B17BF - LEFT SIDEMARKER LAMP CONTROL CIRCUIT OVERCURRENT
B17C4 - RIGHT SIDEMARKER LAMP CONTROL CIRCUIT OVERCURRENT
B1801 - DRIVER DOOR LOCK/UNLOCK SWITCH CIRCUIT LOW - CLUSTER
B1806 - PASSENGER DOOR LOCK/UNLOCK SWITCH CIRCUIT LOW - TIPM
B1934 - DRIVER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK - CLUSTER
B1935 - PASSENGER DOOR LOCK/UNLOCK SWITCH CIRCUIT STUCK - TIPM
B1A08 - RKE FOB 1 PERFORMANCE
B1A09 - RKE FOB 2 PERFORMANCE
B1A0A - RKE FOB 3 PERFORMANCE
B1A0B - RKE FOB 4 PERFORMANCE
B1A0C - RKE FOB 5 PERFORMANCE
B1A0D - RKE FOB 6 PERFORMANCE
B1A0E - RKE FOB 7 PERFORMANCE
B1A0F - RKE FOB 8 PERFORMANCE
B1A10 - RKE FOB 1 BATTERY LOW
B1A11 - RKE FOB 2 BATTERY LOW
B1A12 - RKE FOB 3 BATTERY LOW
B1A13 - RKE FOB 4 BATTERY LOW
B1A14 - RKE FOB 5 BATTERY LOW
B1A15 - RKE FOB 6 BATTERY LOW
B1A16 - RKE FOB 7 BATTERY LOW
B1A17 - RKE FOB 8 BATTERY LOW
B1A20 - PRE-ARM TIMEOUT
B1A23 - RKE RECEIVER PERFORMANCE
B1A24 - KEY NOT PROGRAMMED
B1A25 - INVALID KEY
B1A26 - MAXIMUM NUMBER OF KEYS PROGRAMMED
B1A27 - SKREEM PROGRAMMING PERFORMANCE
B1A28 - ECM MISMATCH WITH SKIM
B1A29 - SKIM BASESTATION MISMATCH
B1A3C - INTERNAL SIREN BATTERY
B1A3D - SIREN BATTERY / LOSS OF POWER SUPPLY
B1A3E - SIREN/ITM MISMATCH
B1A3F - ITM ARMING SEQUENCE PERFORMANCE
B1A48 - INTRUSION SENSOR 1 INTERNAL
B1A5F - INTRUSION SENSOR 2 INTERNAL
B1A6D - INTRUSION SENSOR 3 INTERNAL
B1B00 - DRIVER AIRBAG SQUIB 1 CIRCUIT LOW
B1B01 - DRIVER AIRBAG SQUIB 1 CIRCUIT HIGH
B1B02 - DRIVER AIRBAG SQUIB 1 CIRCUIT OPEN
B1B03 - DRIVER AIRBAG SQUIB 1 CIRCUIT SHORTED TOGETHER
B1B04 - DRIVER AIRBAG SQUIB 2 CIRCUIT LOW
B1B05 - DRIVER AIRBAG SQUIB 2 CIRCUIT HIGH
B1B06 - DRIVER AIRBAG SQUIB 2 CIRCUIT OPEN
B1B07 - DRIVER AIRBAG SQUIB 2 CIRCUIT SHORTED TOGETHER
B1B08 - PASSENGER AIRBAG SQUIB 1 CIRCUIT LOW
B1B09 - PASSENGER AIRBAG SQUIB 1 CIRCUIT HIGH
B1B0A - PASSENGER AIRBAG SQUIB 1 CIRCUIT OPEN
B1B0B - PASSENGER AIRBAG SQUIB 1 CIRCUIT SHORTED TOGETHER
B1B0C - PASSENGER AIRBAG SQUIB 2 CIRCUIT LOW
B1B0D - PASSENGER AIRBAG SQUIB 2 CIRCUIT HIGH
B1B0E - PASSENGER AIRBAG SQUIB 2 CIRCUIT OPEN
B1B0F - PASSENGER AIRBAG SQUIB 2 CIRCUITS SHORTED TOGETHER
B1B54 - 1ST ROW PASSENGER SEAT BELT SENSOR CIRCUIT LOW
B1B55 - 1 ST ROW PASSENGER SEAT BELT SENSOR CIRCUIT HIGH
B1B56 - 1 ST ROW PASSENGER SEAT BELT SENSOR CIRCUIT OPEN
B1B70 - UP-FRONT LEFT SATELLITE ACCELERATION SENSOR INTERNAL
B1B71 - UP-FRONT RIGHT SATELLITE ACCELERATION SENSOR INTERNAL
B1B72 - LEFT SIDE SATELLITE ACCELERATION SENSOR 1 INTERNAL
B1B75 - RIGHT SIDE SATELLITE ACCELERATION SENSOR 1 INTERNAL
B1B78 - PASSENGER SEAT WEIGHT SENSOR 3 - LEFT FRONT PERFORMANCE
B1B79 - PASSENGER SEAT WEIGHT SENSOR 3 - LEFT FRONT INPUT CIRCUIT LOW
B1B7A - PASSENGER SEAT WEIGHT SENSOR 3 - LEFT FRONT INPUT CIRCUIT HIGH
B1B7D - PASSENGER SEAT WEIGHT SENSOR 2 - RIGHT FRONT PERFORMANCE
B1B7E - PASSENGER SEAT WEIGHT SENSOR 2 - RIGHT FRONT INPUT CIRCUIT LOW
B1B7F - PASSENGER SEAT WEIGHT SENSOR 2 - RIGHT FRONT INPUT CIRCUIT HIGH
B1B82 - PASSENGER SEAT WEIGHT SENSOR 4 - LEFT REAR PERFORMANCE
B1B83 - PASSENGER SEAT WEIGHT SENSOR 4 - LEFT REAR INPUT CIRCUIT LOW
B1B84 - PASSENGER SEAT WEIGHT SENSOR 4 - LEFT REAR INPUT CIRCUIT HIGH
B1B87 - PASSENGER SEAT WEIGHT SENSOR 1 - RIGHT REAR PERFORMANCE
B1B88 - PASSENGER SEAT WEIGHT SENSOR 1 - RIGHT REAR INPUT CIRCUIT LOW
B1B89 - PASSENGER SEAT WEIGHT SENSOR 1 - RIGHT REAR INPUT CIRCUIT HIGH
B1B8D - DRIVER SEAT TRACK POSITION SENSOR CIRCUIT LOW
B1B8E - DRIVER SEAT TRACK POSITION SENSOR CIRCUIT HIGH
B1B8F - DRIVER SEAT TRACK POSITION SENSOR CIRCUIT OPEN
B1B93 - PASSENGER SEAT TRACK POSITION SENSOR CIRCUIT LOW
B1B94 - PASSENGER SEAT TRACK POSITION SENSOR CIRCUIT HIGH
B1B95 - PASSENGER SEAT TRACK POSITION SENSOR CIRCUIT OPEN
B1BA5 - AIRBAG SQUIB CONFIGURATION MISMATCH
B1BA6 - OCCUPANT CLASSIFICATION UNDETERMINED
B1BA7 - OCCUPANT CLASSIFICATION SYSTEM VERIFICATION REQUIRED
B1BA8 - OCM SYSTEM OUT OF CALIBRATION/NOT CALIBRATED
B1BAA - OCCUPANT CLASSIFICATION MODULE CONFIGURATION MISMATCH
B1BBA - PASSENGER SEAT WEIGHT SENSOR SUPPLY CIRCUIT
B1BBB - PASSENGER SEAT WEIGHT SENSOR INPUTS SHORTED TOGETHER
2007 JK Unlimited 6 Speed 4.10 Gears
3 Inch BDS Lift
35x12.5x16 Yokohama Geolander AT/S
16x8 Cragar Soft 8 Black Steel Wheels
Custom front Winch Bumper from RoundStar OffRoad
Mopar Offroad Rear Bumper
Oilpan/Tranny skid Plate by Skid Row
JKS Quicker Disconnects
Skyjacker Brake line extenders
Skyjacker Adj Rear track bar
High Clearance Adj Front Lower Control Arms by RocKrawler
RocKrawler Front Lower Control Arm Mounting Bracket/Skid Plates
Warrior Products Rear Safari Doors
Plenty of ROCKRASH
B1A25 - INVALID KEY
3 Inch BDS Lift
Plenty of ROCKRASH
U0010 - Can Interior Bus
U0011 - Can Interior Bus Off Performance
U0019 - Can Interior Bus(+)/(-) Circuit
U0020 - Can Interior Bus Off Performance
U0100 - Lost Communication With Ecm/pcm
U0101 - Lost Communication With Tcm
U0114 - Lost Communication With Final Drive Control Module
U0121 - Lost Communication With Abs
U0121 - Lost Communication With Anti-lock Brake Module
U0121 - Lost Communication With Anti-lock Brake System (abs) Control Module
U0126 - Lost Communication With Sas - Can C (steering Angle Sensor)
U0141 - Lost Communication With Fcm
U0141 - Lost Communication With Front Control Module (tipm)
U0146 - Lost Communication With Central Gateway
U0151 - Lost Communication With Occupant Restraint Controller (orc)
U0154 - Lost Communication With Occupant Classification Module
U0155 - Lost Communication With Cluster/ccn
U0155 - Lost Communication With Cluster/ccn (skreem)
U0161 - Lost Communication With Compass Module
U0164 - Lost Communication With Hvac Control Module
U0167 - Lost Communication With Intrusion Transceiver Control Module
U0168 - Lost Communication With Vehicle Security Control Module (skreem-wcm)
U0168 - Lost Communication With Vehicle Security Control Module (skreem/wcm)
U0170 - Lost Communication W/up-front Left Satellite Acceleration Sensor
U0171 - Lost Communication W/up-front Right Satellite Acceleration Sensor
U0172 - Lost Communication W/left Side Satellite Acceleration Sensor 1
U0175 - Communication W/right Side Satellite Acceleration Sensor 1
U0184 - Lost Communication With Radio
U0186 - Lost Communication With Audio Amplifier
U0193 - Lost Communication With Traffic Information Receiver Module
U0195 - Lost Communication With Sdars
U0197 - Lost Communication With Hands Free Phone Module
U0197 - Lost Communication With Hands Free Module
U0199 - Lost Communication With Drivers Door Module
U0200 - Lost Communication With Passenger Door Module
U0415 - Implausible Data Received From Abs
U0447 - Implausible Data Received From Central
U1008 - Lin 1 Bus
U1008 - Lin 1 Bus
U110a - Lost Communication With Scm
U110c - Lost Fuel Level Message
U110d - Lost Communication With Security Siren
U110e - Lost Ambient Temperature Message
U110f - Lost Fuel Volume Message
U1110 - Lost Vehicle Speed Message
U1113 - Lost A/c Pressure Message
U1120 - Lost Wheel Distance Message
U113b - Lost Communication With Switch Bank Module
U1149 - Lost Communication With Multifunction
U1159 - Lost Communication With Asbs
U1169 - Lost Communication With Intrusion Sensor 1
U1170 - Lost Communication With Intrusion Sensor 2
U1179 - Lost Communication With Intrusion Sensor 3
U1403 - Implausible Fuel Level Signal Received
U1411 - Implausible Fuel Volume Signal Received
U1412 - Implausible Vehicle Speed Signal Received
U1414 - Implausible/missing Ecu Network Configuration Data
U1415 - Implausible/missing Vehicle Configuration Data
U1416 - Implausible Security Siren Signal Received
U1417 - Implausible Left Wheel Distance Signal Received
U1418 - Implausible Right Wheel Distance Signal
U1419 - Implausible Data Received From Ocs Sensor 3 - Left Front
U141a - Implausible Data Received From Ocs Sensor 2 - Right Front
U141b - Implausible Data Received From Ocs Sensor 4 - Left Rear
U141c - Implausible Data Received From Ocs Sensor 1 - Right Rear
U1008 - Lin 1 Bus
U1008 - Lin 1 Bus
Tried that little trick you described to search for error messages. All I get is dotted lines and then the computer displays "done" which leads me to believe it could not find any problems.
I was able to straighten my steering wheel out today as it was off center after the lift install. I played around with it for some time and no matter how "centered" I think it is, I still have the ESP light on constantly.
Also tried discnoonecting the battery to see if that would help reset the computer but that did not work. Looks like a trip to the dealer in in order.
Stupid light!!
Stupid light!!
