Problems!!!!
Old Apr 2, 2009 | 01:22 AM
MORTON's Avatar
Default Problems!!!!
Ok I adjusted my dif angle by lenghtening the top rear control arms, so it would soften the drive shaft angle I get that done. Then a notice in doing so the drive shaft is perfectly straight with the 4 inch lift I have going. But the I see that somthing hit my rear FOX shock piercing the remote hose wich sucks thats now $30 plus the $20 shock oil then the caust in the nitro recharge
Ok Im past that but the real problem is that the coils are bent in a not so good way so some one said to cut and relocate the coil perch. Sound cool I think that would do it. Except now I see that the rear swaybay conects are hiting the large sqare metal piece that the shocks mount to because of the angle change. So now what do I need a different sway bar or what? I know I should have the dif tipped up in the front I see everyone else looks like they do Please help Thanks
Old Apr 2, 2009 | 02:09 AM
mmcan's Avatar
Pictures, man. Pictures,...
Old Apr 2, 2009 | 03:03 AM
RedneckJeep's Avatar
ummmm.....what?!?!?!?
Old Apr 2, 2009 | 03:12 AM
abetterview's Avatar
you have to cut and relocate the spring perches and then the spring will be fine. i did it so that part is no prob.......now on the sway bar ill need a pic to see the prob cause i dont have that prob with mine and i got my pinion angle way up
