Problems after Leveling Kit Install
Old Jan 2, 2013 | 07:04 AM
Red Sahara's Avatar
Default Problems after Leveling Kit Install
So, on Sunday I installed the Teraflex leveling kit (spacers). I noticed yesterday that it was driving alittle funny. I took a look under the Jeep and one of the sway bar links (passenger side) is missing the nut on the top. I have one side of the sway bay disconnected. We did torque all bolts down. I had someone come behind me and check to make sure. I did not re-torque, but they were done initially. I am going to see if 4-Wheel Parts has some hardware that I can have to replace what is missing.
Any ideas on why this happened? I am sure this was user error as I have heard nothing but good things about Teraflex.
Old Jan 2, 2013 | 07:07 AM
JK yeti's Avatar
You should always REtighten the bolts after a couple of hours/days of driving. It takes time for the bolts to settle in there
Old Jan 2, 2013 | 07:11 AM
Red Sahara's Avatar
Thanks for the quick reply. I am going to learn that lesson after new ones are installed.
Old Jan 2, 2013 | 07:32 AM
fultonromero12's Avatar
I had the same noise coming from the front after installing my teraflex. I decided to check the noise after hitting a speed bump in Walmart parking lot. I managed to catch the nut before it was completely off. I would check with 4 wp or take the one off the other side and go to grainger or hardware store to match them up exactly.good luck
Old Jan 4, 2013 | 01:48 PM
Red Sahara's Avatar
Was able to find a matching nut. It is 1/2 inch by 20 for those of you that need it.
Now, I have two questions. I am having trouble getting the nuts tight. What technique should I use to tighten the upper sway bar link bolts? Also, there is a squeak coming from the front end after install. The springs are seated fine and they are in the right place. Any suggestions would be great.
Old Jan 4, 2013 | 02:08 PM
TeraFlex's Avatar
Sponsoring Manufacturer
There is a allen hole on the end of the stud for a allen wrench to go into. That's how your tighten those down.
Old Jan 5, 2013 | 11:26 PM
AndrewJ's Avatar
I just lost a link too on my TF leveling kit. The top nut must have come loose at some point and I never noticed. It wore all the threads off the bolt and eventually pulled right out on a trail last weekend after the nut fell off. I have new links adjustable links on the way, shes a little rollie in the corners right now hahah. Put the lift in a year ago, and the drivers side one is still tight so dunno how the one side came loose.
Old Jan 6, 2013 | 07:32 AM
NTX Jeep's Avatar
What about using blue Loctite during install to keep them from backing off?
