Procomp 8179 problems?
i have read about some success stories about 15 x 8 and 15 x 10
are there anybody with problems installing?. rubbing?..wheel spacers???
im trying to order from 4 wheel parts locally...(they are telling me these will not fit)..now im confused...
please help!...
thanks
trent
please help!...
thanks
trent
IMO go with an 8 not a 10 and if you are ordering wheels just get the proper backspacing and forget about those wheel spacers. You can air down an 8 and not be to worried about the bead busting.
https://www.jk-forum.com/forums/modified-jk-tech-2/procomp-8179-15x10-test-fit-50608/
Will answer your 8179 question. Better late than never.
I have the 8069's in 15x10 (very similar to the 8179, but no fake beadlocks). Fit fine on my Rubicon with no rubbing. The front calipers are fairly close, but the rim's shape fits great. I was prepared to do a bit of grinding, but it was not necessary.
I run the 8179 in the 15 X10 size with no brake clearance issues but the back spacing pushes the tires outside of the stock fenders around 2 to 2/1/2 inchs while running a 33 X 12.5 tire. They hit the fenders hard at full flex with no lift and i have found this set up to be the easiest way to remove your stock fenders. I am looking at the River Raider fenders to remedy my problem. if you are looking for the wider stance, go with the 15 X 10. If you dont plan a lift or fender replacement, go with the 8's.
