ProComp wheels with 5" back spacing
Old Feb 28, 2008 | 02:43 PM
SH0RTBUS's Avatar
Default ProComp wheels with 5" back spacing
Is anyone running 18" wheels with 5" of back spacing and no offset? Are there any issues with rubbing? I really like the ProComp 7005 and noticed there are a few members running them, but not sure if they are running spacers or not. Thanks!
Old Feb 28, 2008 | 02:44 PM
FJ Eater's Avatar
Can you run 5x5.5 ona jk?
Old Feb 28, 2008 | 04:48 PM
rp41's Avatar
They make that wheel in a 5x5 18. To answer your question I had 6016 pro comp with 5.5 offset with 13.5 wide tire and needed about 1/2 inch more clearance in the rear. The front was good other than trimming the air dam and a couple washers in the steering stops. It seems 4.75 is the BS you need for good clearance. Hope this helps
