Programmer for a regear and warranty work
Old Apr 24, 2016 | 06:32 AM
Madmax1221's Avatar
Default Programmer for a regear and warranty work
Hey guys new to this forum but got my JK ( 2014 unlimited) re-geared and now I have a question...
1. I have an auto so I need a programmer or else my jeep will go into limp mode .I have a super chips which I have had for a while now and I always flash back to stock before it goes in for anything at the dealer but now I cant flash back to stock when I go to the dealer for warranty work. What are guys doing to remedy this?
Old Apr 24, 2016 | 06:39 AM
Zimmy5280's Avatar
Good question. I did the same thing but I figured I was long past the stealer ship and warranties now! Hope to not find out though!
Zimmy5280
Old Apr 24, 2016 | 08:10 AM
Madmax1221's Avatar
Zimmy5280
Yea I still have 25,000 km and I have a persistent check engine light ( multiple cylinder misfire ) which has been to the dealership probably 5 times now and they just keep " updating " it and it wont go away. So trying to figure out how to go about this now that it is back in again and I've re-geared
Old Apr 24, 2016 | 08:13 AM
mhockey9090's Avatar
Vet Army
Uninstall the chip in the parking lot and drive it into the bay. I made the mistake of trying to in install mine at home and drive it there haha. Realized quickly that I should have waited. Some dealers are cool and won't care that its flashed.
Old Apr 24, 2016 | 08:19 AM
jadmt's Avatar
JK-Forum Ambassador
what happens when they take it for a test drive? Some warranty repair work requires a test drive.
for the OP. I would get an aev procal and just leave it programmed. AEV procals don't go deep enough into the ecm to cause problems with warranty and for most things that you would need warranty work on wont cause and issue. your super chip may not cause an issue either that I don't know.
Old Apr 24, 2016 | 09:22 AM
Vet Army
Well that depends on what type of warranty work you're getting obviously. My dealer doesn't care, so I don't have that issue here. Depends on how you talk to them.
Old Apr 24, 2016 | 09:49 AM
Madmax1221's Avatar
Yea for me they do care, which means I have to uninstall my programmer. I would even be hesitant to get an aev procal... I could see them even saying something about that. I honesty think my superchips is what is causing this multiple cylinder misfire codeanyways.
Old Apr 24, 2016 | 10:38 AM
Jonathan_JK's Avatar
Default Pro-cal
I say get a pro-cal. I have taken my jeep to the dealer a few times they didn't even say anything about it to me. I bet they don't know it's even there. Or they just don't care.
Old Apr 24, 2016 | 10:57 AM
karls10jk's Avatar
If you can't drive it in limp mode without a tuner and you already believe it's the superchips causing the issue then it makes sense, going with your logic, to sell the SC and go procal.
But let's eliminate the superchips first. Just tune for tire size and gear ratio. Without changing the tune you can pretty well eliminate the superchips as the root of your issue. You've checked plugs? You've checked plug wires? You've made sure the ignition box isn't inadvertently wet?
Old Apr 24, 2016 | 11:29 AM
nthinuf's Avatar
The flashpaq functions as both a programmer and a tuner.
Remove whatever tune you are running, but keep the gear ratio and tire size. It will be no different than using a procal programmer.
