Prorock44 vs rj60
Old Jan 2, 2015 | 06:43 PM
cormac827's Avatar
Originally Posted by Rebar-7
Mopar just released the D60's for the JK's You can get both front and rear with either 4:88's or 5:38's 35 spline axle shafts with eaton E-lockers included Rear axle 7K....front...4K They bolt right in no mods FR/ axle p/n# P5156276AB RR / axle p/n# P 5156278AB
4k front built with gears and locker? Seems cheap!
Old Jan 2, 2015 | 07:07 PM
Rebar-7's Avatar
The rears are full flout , fronts have lockout hub's they are 69"wms
No castor correction, but with lockout front hubs you can run a steeper pinion angle....
Old Jan 2, 2015 | 07:12 PM
sam30540's Avatar
The rears are full flout , fronts have lockout hub's they are 69"wms No castor correction, but with lockout front hubs you can run a steeper pinion angle....
Dirt man
Is 69" wide enough to run 40s w a 3.5" backspaces wheel?
Old Jan 2, 2015 | 07:13 PM
TheDirtman's Avatar
I think he got his numbers reversed 7k for the front and 4k for the rear. My full blown full float prorock 60 with ARB was just a shade over 6k
Old Jan 2, 2015 | 07:15 PM
Jeek.OlllllllO's Avatar
If you are gonna wheel your jeep on tough trails like the hammers you should go with 60's and 37's and full float, a 44 isn't strong enough for hammers type wheeling. Going to 37's you also have to keep in mind your steering you have to beef that up or else your going to break your sector shaft and that's a really bad break out on the trail!
Old Jan 2, 2015 | 07:24 PM
TheDirtman's Avatar
Originally Posted by sam30540
Dirt man
you can run a 40x13.5" with 3.5" bs wheels but still may rub a bit depending on shock travel and suspension set up.
Old Jan 3, 2015 | 05:26 AM
sam30540's Avatar
What are your thoughts on running wheel spacers on the new mopar ultimate 60s? Bora makes a nice steel spacer in 8x6.5. They are built to 69" wide and I can't figure out why they didn't make them 72" wide to start with
Old Jan 3, 2015 | 05:50 AM
Rebar-7's Avatar
Opps you are correct...
Old Jan 3, 2015 | 06:35 AM
TheDirtman's Avatar
Should be fine, I run a 2" on the rear and a 1.5" on the front. Ballistic has aluminum adapters that would be lighter. One benefit of running adapters on the axles is that it keeps the hubs tucked in if you play in the rocks.
Old Jan 3, 2015 | 06:55 AM
sam30540's Avatar
Thanks dirtman
