Pros and Cons of re-gearing please...
Old Jan 12, 2008 | 01:12 PM
Default Pros and Cons of re-gearing please...
Do you really need to regear? What about the loss in gas mileage and increased force on other components?
Please advise...
Thanks
Old Jan 12, 2008 | 01:29 PM
fyerman69's Avatar
All depends on your setup. If you are running tires bigger than 33" there is no doubt you will NEED to regear. This choice is not taken lightly as the average cost of re-gearing is around $750 an axel (I think), and take some professional know-how.
On your Rubi it comes stock with 4.10 gears which should keep you in good standing for 33" tires. In terms of gas mileage.......It's a JEEP! (But seriously, if you went with 35" tires and did NOT re-gear the gas mileage would suck even MORE because you are overtaxing your engine. Pair the right setup of tires with the right setup of gears).
If this is your daily driver and just want "the look", better seek out more advice elsewhere.
Use the "Search" feature for ALL your needs. Plenty of people have shown what they have done with their setups in other threads
Old Jan 12, 2008 | 03:54 PM
Sv650's Avatar
The JK is available (standard) with 3.21 gears and 32" tires. This gives equal final drive ratios as 3.73's with 36" tires, or 4.10's with 40" tires.
I would expect that larger tires cause other issues in the drive train, but simply from the perspective of engine RPM vs. wheel RPM, there is a lot of latitude.
SV
Old Jan 12, 2008 | 05:44 PM
releve's Avatar
Default is it worth the cost?
Would it be worth the cost going from 3.21's to 3.73 on 35" tires?
What I do like about the 3.21's is that its has a long first gear (20 - 25 mph).
I use the car daily on a 20 mile round trip in really really bad traffic.
Old Jan 12, 2008 | 05:52 PM
JKSTER's Avatar
its a 4X2, i think you would be wasting your money to go with bigger tires or re-gearing -- just enjoy it, spend your money on bolt-ons that you can see and i think you'll be happier -- just my opinion --- or trade it in for a 4WD and get a second on the house and go JEEP CRAZY like the rest of us
Old Jan 12, 2008 | 06:05 PM
ROKLIMO's Avatar
Originally Posted by releve
...I use the car daily on a 20 mile round trip in really really bad traffic.
Another Kitten...
Old Jan 12, 2008 | 06:13 PM
JKSTER's Avatar
its like watching a heavyweight fighter washing dishes for a living
Old Jan 12, 2008 | 06:56 PM
Piginajeep's Avatar
if your going to run 37's and are regearing, atleast go to 4.88's
and please dont call a jeep a car...
Old Jan 12, 2008 | 06:57 PM
Piginajeep's Avatar
SV
i think your way off on your estimates...
I dont think it would move with 4:10's and 40's
Old Jan 12, 2008 | 07:31 PM
IGOFSHN's Avatar
based on this gear chart, it is pretty close.
http://www.4lo.com/calc/geartable.htm
32 and 3.21 @65 is about 2200 rpm, 40's and 4.10's is also about 2200. Although, I'm with you on doubting that it probably wouldn't move very well, let alone get up to 65.
