Pros and Cons of re-gearing please...
A lot has to do with expectations.
Its a truck, it drives like a truck.
I have the 255/75/17's, essentially 32's...and I got the 3.73 gearing on a manual tranny.
I went through the gears to get a feel for the rpm ranges, and jotted down a few numbers:
1st gear at 4 k rpm = 21 mph
2nd gear at 4 k rpm = 38 mph
3rd gear at 4.1 K rpm = 59 mph
4th gear at 3 K rpm = 59 mph
5th gear at 2.4 K rpm = 59 mph
6th gear at 2 k rpm = 59 mph
_______________________________________
A quick look at the revolutions per mile for a few tire sizes:
my 32's = 660 rpm
33's = 630 rpm
35's = 600 rpm
37's = 570 rpm
__________________________________________
If you do the math, lets say from 6th gear at 2k rpm cruising at 59 mph (To stay cruising at 59 mph)...the rpm would drop by tire size like so:
At 59 mph, in 6th, compared to stock:
32's = No Drop = Stock = 2,000 rpm at 59 mph
33's = 91 rpm drop to 1,909 rpm at 59 mph
35's = 182 rpm drop to 1,818 rpm at 59 mph
37's = 272 rpm drop to 1,728 rpm at 59 mph
___________________________________________
Dropping to 5th gear from 6th, stock, raised the 2,000 rpm by 400 rpm to 2,400 rpm
IE: Going from 32's to 37's was not enough of a difference to even span one gear range.
Essentially, going from 32's to 37's Raised the gearing/Dropped the rpm by 13.6 %/in any given gear across the range.
35's came out to a 9.1% change.
33's came out to a 4.5% change.
32's come out to a zero percent change, etc.
So, if I were to do the same math for any of the other speed/rpm combo's above...I could see what my rpm drop for each tire size might be at any given combo.
An obvious solution to gearing issues...downshift if you want to raise your rpm.
Your final drive ratio is the same, as your tires are actually PART of your REAL final drive ratio....
So, it makes no difference if you are going 2,000 rpm at 59 mph in 6th, 5th, or whatever...its still 59 mph at 2,000 rpm as far as the Jeep knows.
The rolling resistance, the taller wind profile, and so forth make more of a difference than your gearing when you get down to it.
So, sure, lower gearing DOES improve power/raise the rpm...but, to me at least, its just not enough of a difference to spend that kind of money re-gearing to get 13.9 % of my rpm back.......when I can downshift for free...........for others....its a priority.
my 32's = 660 rpm
33's = 630 rpm
35's = 600 rpm
37's = 570 rpm
my 32's = 660 rpm
33's = 630 rpm
35's = 600 rpm
37's = 570 rpm
my 32's = 660 rpm
33's = 630 rpm
35's = 600 rpm
37's = 570 rpm
I'm running 35's on the stock 4.10's, and I don't think it's nearly as bad as everyone says. I haven't done any heavy wheeling with it yet, but I have done a good bit of mountain driving. It's not fast, by any means. But it wasn't fast when I pulled off the dealer's lot either.
I have 3.21's and 33.4' tires, the only time I have a problem is highway and passing (I just shift down lower) or climbing in the mountains (again I just down shift).
I have been offroad and not had a problem in 4 hi or 4 lo, now I don't do blacks or reds but no problems with blues. If it were an auto, I would hate life.
I will eventualy regear to 4.1's but I am in no hurry. It is not much more of a dog then when I got it. When I bought it I new it wasn't a race car.
One thing I see over and over again when people talk about a loss in mpg when they get larger tires:
They forget to recalculate their speed, and their miles.
IE:
1) They have 35's, and the speedometer is reading 9.1% low....so, they are cruising along at 65 mph like they always do, but they are really going 71 mph, which uses a lot more gas in a brick shaped projectile.
So - They are driving faster than they think they are...and they lose a few mpg.
2) They hit the gas station, and see that they only went 240 miles instead of 300 miles between fill-ups, and think, WOW, those big tires really KILLED my gas mileage!
So - if you want to really know your mpg....and compare it to your "Before" mpg....
Say for those 35's -
...remember that you have to drive about 10% slower than what the speedometer says you're going (Makes the math easy that way) to get down to the real speed you wanted.
So - if you WANT to drive at 65 mph - your SPEEDOMETER needs to be reading about 59 mph.
If you want to go 60 mph, your speedometer needs to read about 54 mph, etc.
That will correct for using more gas to go too fast. (BUT - IS very handy for pointing to the wife, etc, and saying, "What, no, look, I'm not speeding...")
and - when you get to the pump and hit the trip odometer to see how many miles you drove, add about 10% to the number of miles driven as well.
So - if it says you went 270 miles, add 27 miles to that, and write down that you went 297 miles.
(The 10% works well because when ADDING to the artificially REDUCED number, it takes an increase of about 10% to be equal to the SUBTRACTION of the 9.1% from the LARGER REAL number)
IE:
If the odometer reads 270 miles traveled, but its off by 9.1%, and you add 9.1% to 270, you get 294.6 miles.
If you really travelled 297 miles, and subtract 9.1%, you get 270 miles.
If you add 10% to the 270 miles instead of 9.1%, you get 297, the true number.
_______________________________________________
Summary -
Don't make the mistake of driving faster than you thought, and going further than you thought, and then assuming the tires killed your mpg (As badly).
IE:
IE:
Summary -
I think i understand...The bottom line is that we didnt get into jeeps to pass people on the highway...or to get better than 20 mpg's...we got into jeeps to get away from it all deep in the woods. The math lesson above was very eye opening and was effective in that it brought me back to reality. maybe I need a simple budget boost and some new fenders instead. And after studying every post in this whole darned site I think I'll just relax and do my mods in stages...maybe gears will come later.
Thanks dudes,
Thanks dudes,
based on this gear chart, it is pretty close.
http://www.4lo.com/calc/geartable.htm
32 and 3.21 @65 is about 2200 rpm, 40's and 4.10's is also about 2200. Although, I'm with you on doubting that it probably wouldn't move very well, let alone get up to 65.
I think that the 4.56 gears are a perfect match for 33" tires. I'd go with 4.88's for 35" tires.
My 2 cents
You can use the calculations below the table if you wish to corroborate the mumbers in the table; it's pretty straightforward math.
SV
The JK is available (standard) with 3.21 gears and 32" tires. This gives equal final drive ratios as 3.73's with 36" tires, or 4.10's with 40" tires.
I would expect that larger tires cause other issues in the drive train, but simply from the perspective of engine RPM vs. wheel RPM, there is a lot of latitude.
SV
SV
http://www.quadratec.com/jeep_knowle...article-26.htm
