ProSteer Ball Joints users,
Old Nov 30, 2009 | 08:46 AM
longshank's Avatar
Default ProSteer Ball Joints users,
Hello all,
Anybody fitted these, or other grease able ball joints, rather than the limp jeep ones.
The price of near $600 dollars for a set is a lot , any others out there cheaper, , my front end is looser than a bowl of watery custard, and cant be assed with the local Limp Jeep dealer, saying, "oh thats normal"
Help needed accross the pond.
Old Nov 30, 2009 | 08:49 AM
wayoflife's Avatar
JK-Forum Founder
the ProSteer Ball Joints are the only aftermarket ball joints that i know of that are actually beefed up and by a lot. they are definitely pricy but probably the very last set you will ever need to install. if you do a search, there are guys on this forum who are on their 5th set of ball joints so, these may be worth the investment.
Old Nov 30, 2009 | 09:19 AM
jeepnick's Avatar
i enjoyed that
im interested in this too
Old Nov 30, 2009 | 09:56 AM
Hellbound13's Avatar
Are these only if you need a camber adjustment, or can these simply be swapped out to replace the stock ones? Also are they available yet?
Old Nov 30, 2009 | 12:57 PM
longshank's Avatar
Default Replacement ball joints
Well are there any other replacement joints out there, i looked and looked, but cant find any.
Emailed Dyno 24 hours ago, and no reply, so stuck really.
Old Nov 30, 2009 | 01:03 PM
wayoflife's Avatar
JK-Forum Founder
these are NOT offset ball joints - just heavy duty replacements.
sure, crown makes some direct replacements and they are pretty cheap but i don't think they are any strong than stock
Old Nov 30, 2009 | 01:25 PM
Thanks WOL.
I emailed Dyna as well, waiting to hear back on how to order.
WOL,
I can literally just swap these and be good to go without any adjustment if I am stock height, correct?
Old Nov 30, 2009 | 01:30 PM
wayoflife's Avatar
JK-Forum Founder
Thanks WOL.
WOL,
first off, if you're ball joints aren't bad, there is no need to change them out. second, lift height makes no difference whether or not you can use these ball joints. but, to answer your question, yes, you can just swap these in and be good to go - no adjustments are needed.
Old Nov 30, 2009 | 01:33 PM
Thanks!
Old Nov 30, 2009 | 02:07 PM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by planman
Who makes offset ball joints?
My driver's side camber is out of spec.
at the moment, nobody that i know of or at least, not JK specific anyway.
i've seen some listed on jegs and thought about giving them a try but, being that these aren't cheap, i didn't want to buy them just to find out that they don't work.
