PS body armor question
Old Dec 22, 2015 | 09:59 AM
Invest2m4's Avatar
Originally Posted by Boosted
Have you ever removed the armor after its been wheeled for a while?
Yes. Many times. Sealing it is bad news, but you a free to choose whatever method you prefer.
Old Dec 22, 2015 | 10:02 AM
Invest2m4's Avatar
Without a seal, there is enough gap to wash between with water. It's also enough to dry out of moisture gets in. With a seal, stuff will still get in except the seal does a great job of holding it in. Constant moisture is your enemy and a seal will get you that.
Same thing with axle seals. Crap still gets in, but can't get out.
Old Dec 22, 2015 | 11:51 AM
PsychoCupcake's Avatar
Here you go, this is what was waiting under my corner armor a year after it went on. It's not as bad as it looks. The rust was actually from the armor itself not being prepped properly and was transferring rust into the clear coat of my paint. The nutserts did not provide any standoff and instead my body was slightly warped and puckered which just made the two rub together even worse. I could see running a gasket along the top edge of the corner armor to keep water from going down in and then not sealing the bottom so that any moisture can drain out. Not sure how well that would work or if it would even help at all.
Old Dec 23, 2015 | 04:51 AM
BIGCHRIS's Avatar
A friend of mine runs a 1/8 bead of silicone around the holes and just inside the outer edge and lets it dry for a day, keeps the water out and the armor away from the sheet metal, this year I'm going to give that a try.
Old Dec 23, 2015 | 10:00 AM
Boosted's Avatar
I can see the pro's and con's to both choices. Tough to say which method is best but I prefer to use the rubber seal on the rocker armor and fender flares due to all the contact with rocks. I don't think there is a seal available for the corner armor although if there were, I wouldn't use it as it would probably cause the corner to not fit properly or snug to the tub.
Old Dec 23, 2015 | 11:45 AM
PhxSilver's Avatar
Originally Posted by Ripa777
Looking at getting PS body armor for my JKU.
1) steel or aluminum ?
2) is anyone running the rubber seal that goes between the jeep tub and the body armor... Is that worth the $60??
Thx for help
Are you considering the PS Sliders? If you are you need to PM me first.
Old Dec 23, 2015 | 10:43 PM
Ripa777's Avatar
No. Just PS body armor. Going with rockslide engineering for sliders.
Old Dec 24, 2015 | 12:55 AM
Thadv95's Avatar
I'm looking at the PS sliders
Old Dec 24, 2015 | 06:16 AM
shabbernigdo's Avatar
Coat it with what? Is there something additional other than paint or powdercoating?
Paint works just fine. if you get the steel then its not an issues if you get the alum then you dont want the 2 metals touching directly so just paint them or if they are alredy painted your gtg.
Old Dec 24, 2015 | 04:46 PM
DJ1's Avatar
DJ1
Former Member
Originally Posted by Pthorpe84
Second invest comments. I am a corrosion specialist and the gasket is likely to cause more harm than good. Not having it there will allow the space between to "breathe". The biggest thing is that you coat both sides of the armor regardless if it's steel or aluminum. Dissimilar metals touch will cause a circuit to form and will cause the less noble metal to corrode.
Forget the gasket and coat your armor properly and you will be good to go.
I've got Evo's aluminum rockers (with VKS sliders) which I'm planning to have painted body color. I have heard about the corrosion possibilities if using a rubber liner like the one PS offers. Interesting since Evo's instructions actually call out the applying of a gasket sealant to their rockers prior to installing....
I'll probably skip the sealant...
