PSC High Volume Pump Kit Help!
Old Oct 5, 2012 | 06:33 AM
hapnincapt's Avatar
Default PSC High Volume Pump Kit Help!
I just got this kit and I am going to attempt to install it Saturday. The kit came with no directions and the PSC website does have a tech section, but I am still unsure of the order of everything, or the hose routing/orientation. Can someone confirm or correct me but I think it goes like this: RESERVOIR to PUMP to GEAR BOX to COOLER and back to RESERVOIR. Has someone out there installed this kit? Any feedback will be appreciated. I'm scared to start this and find myself in over my head! Thanks.
Old Oct 5, 2012 | 06:47 AM
GCM 2's Avatar
That is correct;
Low pressure side= the reservoir's bottom outlet is the gravity feed back to the pump on the engine. There should be enough height difference that the reservoir outlet line is higher than where it enters the pump on the front of engine so fluid can constantly be "gravity" fed to the pump.
High pressure side= from pump on engine to steering box, steering box to cooler, cooler back to reservoir.
Hope this helps you, but it sounds like you are all over it!
