PSC ram problem
So I just installed a PSC ram, PSC pump, PSC lines, PSC cooler and drilled out my steering box. over the last week the slow speed and well stopped has gotten worse (stiffer) and now the pump wine's at full stop tying to turn the wheel. does anyone have an idea of the problem or have seen this before.
I had the same issue and it took several attempts to get all the air out. Cavitation can destroy a pump if your not careful. What I did was lift the front of the jeep then turn the steering wheel lock to lock probably 20 times with the reservoir cap off. Are you still having fluctuations in your PS fluid?
