PSC ram problem
Old May 10, 2016 | 06:16 AM
Noroad's Avatar
Default PSC ram problem
So I just installed a PSC ram, PSC pump, PSC lines, PSC cooler and drilled out my steering box. over the last week the slow speed and well stopped has gotten worse (stiffer) and now the pump wine's at full stop tying to turn the wheel. does anyone have an idea of the problem or have seen this before.
Old May 10, 2016 | 06:21 AM
SF Nick's Avatar
Sounds like you still have some air in your PS system.
Old May 10, 2016 | 06:25 AM
Noroad's Avatar
I have been bleeding it like crazy, and tips?(im not getting anymore air out the rez) would that make the pump wine?
Old May 10, 2016 | 06:33 AM
SF Nick's Avatar
I had the same issue and it took several attempts to get all the air out. Cavitation can destroy a pump if your not careful. What I did was lift the front of the jeep then turn the steering wheel lock to lock probably 20 times with the reservoir cap off. Are you still having fluctuations in your PS fluid?
Old May 10, 2016 | 06:36 AM
jedg's Avatar
Vet Army
Yeah, this ^^^. I did the same. Lift the jeep and cycle the steering until I no longer saw fluid level change. Then put the jeep on the ground and cycled again until I saw no fluid level change. Mind you, I'm using an OEM pump and WTO ram so YMMV.
Old May 10, 2016 | 06:37 AM
Noroad's Avatar
that's how bleed it, how do u get air out of the pump if it wont come out? and the fluid level is staying the same.
