PSI on road?
I chalk tested them, and 27-28 seemed to be the magic number.
Currently, im running Duratracs (same size) on my 4 door with AEV 2.5" and have them at 27.
Like folks have said every vehicle can be weighted a little differently so pressures can vary. We tend to run a 2 psi split between the front and back, so lets say 28 psi in the front and 26 psi in the rear for a tire of that size.
RK
RK
When I got these tires from being mounted, the shop had them at 40 lbs. The Jeep road like a hay wagon, terrible even for a jeep. So I aired down to 30 psi and seems to ride much better. I will do the chalk test to try and dial in the perfect psi for daily driving. Thanks for the input!
Not recommended for 4-dr Jeeps, even less for the lighter 2-dr.
Yes, the side walls of E-rated tires are less prone to be torn by rocks etc', but there are no free meals... they make the overall ride harder, and are less flexible, so they comply less with the terrain.
E-rated tires are for heavier vehicles & loads than our JK(U)s. They are too stiff. Not recommended for 4-dr Jeeps, even less for the lighter 2-dr. Yes, the side walls of E-rated tires are less prone to be torn by rocks etc', but there are no free meals... they make the overall ride harder, and are less flexible, so they comply less with the terrain.
Regardless, the poster asked what he should run his E rated Duratracs at. I appreciate you were trying to be helpful, but telling him (or me), that we shouldn't have bought them in the first place doesn't answer his question. Like they say, that ship has sailed.
