Pull pal substitute
http://www.4wd.com/productdetails.aspx?partID=42341
anyone seen this smittybuilt winch anchor? is this a cheap version of the pull pal you all talk about? first i have seen of it. nice at about 25% of the cost of the pull pal.
i suppose before i got this i would just need a winch
I remember reading a write up on it, and it said it didn't dig in, and I think that the plow actually bent making it ineffective. Smitty used thinner metal to make it cheaper, and in this case if I had a vehicle burried to the frame rails I would want to know that my Pull-Pal could take the weight.
My idea of a pull-pal substitute is a 3-foot length of rebar and a mallet, hammered into the ground at slight angle - nice and cheap, and makes a decent winch anchor provided you're not tooo stuck.
I would think you couldn't get that rebar back out of the ground very easily.
With Scouts we put up a monkey (rope) bridge. There are several ways to anchor it, but we like to use old axles sharpened to a point and pounded into the ground. You can use a Hi-Lift to winch the pegs out of the ground of they don't come free with a little pounding and sweating.
I've tried to pull re-bar out of the ground. It's damn near impossible.
I just hope that no re-bar is left sticking 3 inches out of the ground (after a couple of years of weathering) that makes a better tire poker that it does a winch anchor. Just sayin.
Totally agree, no 4-wheeler should ever screw the next guy or generation - leave no trace !!!
