question about 37" tires
Old Mar 20, 2010 | 10:39 AM
  #21
KenB1010's Avatar
His profile shows a 3.5" lift plus a 1" body lift. That's higher than mine, my shafts lasted awhile, but in the end didn't survive.
Old Mar 20, 2010 | 10:42 AM
  #22
sanyezhong's Avatar
What is the main reason for changing the stock drive shaft, the drive shaft angle changed or the bigger tires need stronger drive shaft or maybe both?
Old Mar 20, 2010 | 10:49 AM
  #23
stlfan06's Avatar
Q: Are new driveshafts needed after installing a lift?
A: You really should consider installing a new rear double cardin U-joint style drive shaft if you have lifted your Jeep JK Wrangler 3" or more and have a 2-door. This is needed because the short rear drive shaft of the 2-doors will be at a steep enough angle that the CV boots will wear out prematurely. However, in order to do this, you will need to buy a set of rear adjustable upper control arms so that you can properly set your pinion angle. 4-Door Unlimited models do not have this problem as their rear drive shafts are very long and a lift will not effect the angle of it too much. As far as the front goes, if you have an automatic transmission, you will need to replace the drive shaft with a double cardin U-joint style unit as well as the diameter of aftermarket shafts will be considerably narrower and will not come into contact with the transmission and/or skid plate. Failure to do this will result in the tearing of the factory drive shaft boot as it makes contact with the transmission. Manual transmissions will not have this problem and keeping the factory front drive shaft will not be a problem.
