Question about 4.88 gears
Old 10-26-2007 | 05:28 AM
thumperk15's Avatar
Default Question about 4.88 gears
What would be the best place to get 4.88 gears for my X model at? I'm buying from a sponser on here too. Also, is there anyone on here that put in there own gears?
Old 10-26-2007 | 06:11 AM
MJS_Jeep_888's Avatar
Can't speak toward price, but as far as service goes, you'd be hard-pressed to find a better vendor than Northridge 4x4... check them out here.
Old 10-26-2007 | 06:21 AM
Rubidonn's Avatar
Your probably talking $600-$700 for the gears... Northridge is a good source for your purchase...
As far as install, if you have someone do it, I'd say it'll be around $800-$900 for the labor. If you haven't done gears before, I wouldn't recommend it. A good gear install is well worth the money spent
Old 10-26-2007 | 06:22 AM
JK07's Avatar
The only person I respect at the moment is David at Northridge. If you want best customer service go to him. And also we should all support him for all is hard work. He even answers his phone on the Sundays to help us out and will give you the right advise.
Old 10-26-2007 | 08:06 AM
HUNTER's Avatar
Default Gears
4x4ROCKSHOP.COM
Has a special $659 gears and overhaul kits free delivery. Ask about shims!!! Not sure what axles need,, mine did and delayed things a bit. Have a pro install lot of trial and error, setting them up.
Quick Reply: Question about 4.88 gears
