Question about ARB lockers
Old Aug 26, 2011 | 06:28 PM
sick jk's Avatar
Default Question about ARB lockers
Hi. Just Picked my jeep up from have gears and front and rear lockers installed. I have 3 switches. One for the compressor, 1 for the the front locker and 1 for the rear locker. When I turn on the compressor the compressor turns in and the switch lights up. When I hit front locker the locker engages and the switch lights up. Same with the rear switch. But, when I turn in the compressor and hit the rear locker before the front locker it doesn't turn on. The guy at 4 wheel parts said that's the way it works. You must engage the front first then engage the rear. Then turn off the front locker if you just want rear locker. Is this correct? Doesn't make sense to me.
Old Aug 26, 2011 | 06:56 PM
zero3's Avatar
My pop has ARB's in his tj and i believe it is compressor, rear, then front, and the front wont engage unless the rear is locked. i know his set up is a little older than your but thought I'd try and help.
Old Aug 26, 2011 | 07:02 PM
sick jk's Avatar
Thanks for the info. That makes more sence to me because your rear locker will be engaged most of the time. More than the front.
Old Aug 26, 2011 | 07:15 PM
nthinuf's Avatar
Here ya go...
IMPORTANT
As a safety precaution, the 'switch 2' position in the wiring loom will not activate unless 'switch 1' is already activated. Therefore, if both front and rear air lockers are installed then the rear MUST be controlled by 'switch 1', and the front by 'switch 2'. This is a safety feature that serves to reduce the risk of the accidental / unintended engagement of the front air locker.
If only one air locker is installed then it should be wired using the terminals for 'switch 1', regardless of whether the air locker is mounted in the front or rear.
It'll be easy for them to swap the wires.
Old Aug 26, 2011 | 07:22 PM
sick jk's Avatar
Originally Posted by nthinuf
Here ya go...
That's exactly what I was looking for. Thanks.
