Question about Teraflex Leveling Kit Install
Hi - I was wondering if this sounded right for a 4X4 shop to install the Teraflex Leveling Kit -
"front alignment is needed and from the photo alinment cams are not included but they are needed they are 39.95. Labor to install the kit will be 252.00 plus 85.00 for alignment."
Link to the kit I want to buy -
http://www.northridge4x4.com/proddet...rod=TF-1155200
Thanks for your help!
Hell no. Don't let them put cam bolts on your Jeep, if you want to adjust caster get adjustable control arms. You can stick with the stock arms in which case you don't need an alignment, the only thing they could adjust is the toe.
Not hard to install a lift, if you have the time and a few tools save yourself money and do it.
Just do the install yourself. Leave the wheels on, unbolt the bottom shock bolt, sway bar end links, and brake line bracket. Jack up each corner by the frame and watch the spring fall out.
WOW! Yeah, I'm no expert, but I did read the PDF file after I emailed the shop. It said nothing about alignment cams
. I also read a write up for a front end alignment... Shows that a little reading can go a long way... Thanks for the input, guys!
I just bought the same kit and a set of take off springs and shocks form a Rubi. I have plans on installing it all myself this Sat. From what i read it's an easy shade tree mechanic job to do! 3 hours max!!
Then again, I'd be eating at the IN-N-OUT Burger and reciting Big Lebowski lines. The Dude Abides!
