Question about Teraflex Leveling Kit Install
Old Mar 16, 2010 | 04:18 PM
TeamsterOwl's Avatar
Default Question about Teraflex Leveling Kit Install
Hi - I was wondering if this sounded right for a 4X4 shop to install the Teraflex Leveling Kit -
"front alignment is needed and from the photo alinment cams are not included but they are needed they are 39.95. Labor to install the kit will be 252.00 plus 85.00 for alignment."
Link to the kit I want to buy -
http://www.northridge4x4.com/proddet...rod=TF-1155200
Thanks for your help!
Old Mar 16, 2010 | 04:30 PM
Coby Dick's Avatar
you wont' need a alignment. You can do it yourself in a couple hours. I've got almost 6000 miles on my TF leveling kit. I did it myself, no alignment, and the jeep runs just as smooth and straight as stock.
Old Mar 16, 2010 | 04:42 PM
ScottW's Avatar
Hell no. Don't let them put cam bolts on your Jeep, if you want to adjust caster get adjustable control arms. You can stick with the stock arms in which case you don't need an alignment, the only thing they could adjust is the toe.
Not hard to install a lift, if you have the time and a few tools save yourself money and do it.
Old Mar 16, 2010 | 04:46 PM
Ryan L's Avatar
NOTHING ELSE IS NEEDED... other than what TF gives you. You most likely won't even need to straighten the steering wheel (2 min fix, if that.)
Old Mar 16, 2010 | 04:47 PM
thom1879's Avatar
I recommend you do not return to that shop. That labor is waaaaay high for this simple of a kit.
Old Mar 16, 2010 | 05:59 PM
Ryan L's Avatar
Just do the install yourself. Leave the wheels on, unbolt the bottom shock bolt, sway bar end links, and brake line bracket. Jack up each corner by the frame and watch the spring fall out.
Old Mar 16, 2010 | 07:11 PM
Dylanjam77's Avatar
NO, NO, NO... nothing that shop told you is correct at all...
Old Mar 16, 2010 | 10:12 PM
WOW! Yeah, I'm no expert, but I did read the PDF file after I emailed the shop. It said nothing about alignment cams . I also read a write up for a front end alignment... Shows that a little reading can go a long way... Thanks for the input, guys!
Old Mar 16, 2010 | 10:56 PM
ffemt86's Avatar
I just bought the same kit and a set of take off springs and shocks form a Rubi. I have plans on installing it all myself this Sat. From what i read it's an easy shade tree mechanic job to do! 3 hours max!!
Old Mar 17, 2010 | 12:14 AM
Too bad I'm not in Riverside, we can knock out both JK's! Then again, I'd be eating at the IN-N-OUT Burger and reciting Big Lebowski lines. The Dude Abides!
