Question about wheels
Old Dec 19, 2011 | 03:10 PM
BStelling's Avatar
Default Question about wheels
Hello fellow Jeepers, I have a question about wheels. I'm looking into getting some Method race wheels (non-beadlock) but have a few questions before pulling the trigger. On the websites I'm looking at, they keep saying that the offset is 0mm but no mention of backspacing. How do I know if this is enough to run 37's? I know I need to run at least 4.5 or less of BS but can't find any info on how much BS they have. As well, is a 8.5 in wide wheel enough to run 37's?
This is what I would like to run:
As well feel free to give me any other ideas on which wheels to run. I'd like to run a black wheel. Here is what they will be going on.
Old Dec 19, 2011 | 03:12 PM
Joe Boxer's Avatar
Do some research to find out what the common backspacing is on those wheels... or, at least, call whomever you plan on purchasing them from to ensure you get a 4.5" backspace or smaller.
You can run widths up to a 12.50" wide tire on an 8.5" wheel, if memory serves me correctly.
Old Dec 19, 2011 | 03:14 PM
armycop's Avatar
If it's zero offset, that means it's exactly halfway on the rim making it 4.25" backspacing which is fine for a 12.5" wide tire.
Old Dec 19, 2011 | 03:15 PM
BStelling's Avatar
Sweet! Thanks for the info
Old Dec 19, 2011 | 06:34 PM
Poker5150's Avatar
Also look at the KMC Addicts. I just put them on mine and they look fantastic.
Old Dec 19, 2011 | 07:28 PM
KY JK's Avatar
Not quite. When measuring backspacing you have to add for the lip of the wheel front and back. Example: An 8" wheel actually measures 9", 0 offset would be 4.5 backspacing. 8.5" width wheel 0 offset would be 4.75" backspacing. 9" wheel with a 0 is 5" backspacing, -6 offset is like 4.75 and -12 is 4.5" or so. Someone correct me if I'm wrong here...
Old Dec 19, 2011 | 07:31 PM
KY JK's Avatar
17x9 Addicts with a -12 offset would have a 4.5" backspacing and are the wheels I almost ordered today. Still deciding...
Old Dec 20, 2011 | 12:59 PM
Discount Tire's Avatar
Sponsoring Vendor
You are right You have to account for the wheel flange.
Details: https://www.jk-forum.com/forums/show...ckspace+relate
The Method Wheels are 8.5" wide with a 0 offset which means the backspace is 4.75"
Old Dec 20, 2011 | 04:52 PM
BStelling's Avatar
Went ahead and ordered some Fuel Boost wheels! Should be here next Tuesday
Old Dec 27, 2011 | 07:19 PM
KY JK's Avatar
We have a set of those in my shop. They look MUCH better in person!! Mine came in today now just need time to put them on...
