Question for the tire "pros".
Old Aug 30, 2011 | 06:16 AM
ronjenx's Avatar
Originally Posted by sam187st
Thanks for the heads up on that article, here is a link to it if anyone cars to read it. http://blogs.jpmagazine.com/6658918/...ght/index.html
I read the article. Is there more to it than what shows up on the initial page? It seemed to leave me wanting a little more in depth information.
The author didn't go into how the added weight ratio was arrived at, or what (dynamic) component actually sees the result of the 10:1 ratio.
Old Aug 30, 2011 | 07:01 AM
sam187st's Avatar
lol, i was thinking the same thing, i was like "thats it". I believe it was just a blog entry of some sort and not actually an article.
Old Aug 30, 2011 | 07:40 AM
A 35 foot tire (35') is an awful big tire.
Old Aug 30, 2011 | 10:07 AM
strat_53711's Avatar
Answering the questions regarding torque of equally weight 33" and 35" wheel/tire.
Torque is the tendency of a force to rotate an object about an axis. It's based on Force applied, length of lever arm, and the angle between the force vector and lever arm.
Regarding Jeep wheel/tire combo (Using data from TireRack.com, Goodyear Wrangler MT/R Kevlar)
33x12.5R15 (60 lb) Steel wheel (28 lb) = 88 lbs
35x12.5R15 (67 lb) Alloy wheel (21 lb) = 88 lbs
Your taking away weight which is closer to the spinninig axis (wheel) and adding weight farther (tire tread weight + larger diameter).
This increases the torque needed to get the wheel tire spinning at equal speed.
Old Sep 3, 2011 | 09:31 AM
sam187st's Avatar
just a little more info i found, seems to be some what connected to the blog entry.
http://www.jpmagazine.com/techarticl...n/viewall.html
