Questions about Rubicon axles
Anyway, good luck with the install!
You can use a GM ECM temp sensor harness with some slight modifications for the harness plug in at the axle. Its not a perfect fit , but i used some silicone in the plug for retention along with some zip ties. I used my front ARB switch with a relay under the hood for controling the locker.
I cant get over the difference between ring gear/axle size of the D44 versus my blown to pieces D30!!
Seems like the rubicon axles are the way to go! So it's 100% bolt on? Any alignment shops to deal with???
Strength-wise, how strong are they? Any problems with getting 35's???
Last edited by falconfixer; Mar 11, 2009 at 11:39 AM. Reason: blacklisted manufacturer
Thanks for all the info. I talked to 4wd hardware today and ordered the factory wire harness and switches. They said that there are two seperate switches so I can control front and rear independently
. This does not seem right but when I get the parts in I will let everyone know how it works.
