Quick decision
Old Oct 11, 2011 | 05:04 AM
mlax's Avatar
Default Quick decision
I have deceided to get the TF 2.5 coil lift. The question is whether or not to go with the 4 door version for my 2Dr or just stay with the 2dr? I have a heavy bumper with winch in the front and will be adding a heavy rear with tire carrier this month. I don't want to get into a driveshaft replacement issue. However if the 4dr gets an extra 1/2 inch or so is it worth it or will it cause additional problems.
What else should I replace/upgrade while I have everything apart? Thanks.
Old Oct 11, 2011 | 09:29 AM
08JKRHD's Avatar
I have the 2dr coils and got well over three in the front with a winch and bumper. I ripped my front driveshaft boot the first time I Maxed out the flex at URE. I replaced it with one from Carolina drivetrain.
Old Oct 11, 2011 | 01:04 PM
mlax's Avatar
Do you have any current pics?
Old Oct 11, 2011 | 01:30 PM
atmotocrosser's Avatar
I was wondering the same thing, and after talking to Dave at Northridge4x4 I went with the 4 door kit for my 2011 2 door Sport. He doesn't even keep the 2 door kits in stock since just about every customer goes with the 4 door kit. I hope I made the right decision in trusting his opinion and I will hopefully find out this weekend if I get the lift here in time to install it on Sunday .
Old Oct 11, 2011 | 02:06 PM
w squared's Avatar
The difference between the 2 door coils and 4 door coils will be pretty small. As long as you're not trying to fit 37's in there, you'll probably be fine.
Old Oct 11, 2011 | 05:21 PM
08JKRHD's Avatar
Look in my albums for more
Old Oct 11, 2011 | 05:28 PM
81ster's Avatar
Why not get the correct lift for the 2 door and get 1/2 in spacers for the coils for your extra weight. You will get some natural sag after a couple hundred miles. I would just put the 1/2 spacer in the front for your added weight, so it evens out the rear.
Old Oct 11, 2011 | 05:33 PM
Mcflurry301's Avatar
I got the 4 dr kit from Dave also.. I got way may then 2.5 more along the lines of 3. You will love it
Old Oct 11, 2011 | 05:50 PM
Bubbacon's Avatar
Translation please?
Old Oct 11, 2011 | 05:58 PM
81ster's Avatar
after those new springs settle in you may loose that extra 1/2 in. Then add weight and your back to square one with a nose dive.
