Quick Disconnects
Old Oct 18, 2016 | 05:50 PM
Hoopskier's Avatar
I had both Teraflex and JKS. Quality seemed good to go for either brand. For my setup, found the Teraflex would rub when they were disconnected and on the keeper. I switched to JKS. No rub issues obviously with the link completely removed. Sway bar stays put, with no additional parts. If I need to, zip tie, cheap solution.
Old Oct 18, 2016 | 06:49 PM
DJ1's Avatar
DJ1
Former Member
If you're not going the Currie route, go with the JKS with the Teraflex storage brackets. Killer combo right there. JKS may actually make brackets now similar to the Teraflex.
If you're ever worried about possible rubbing, then at least with the JKS you can pull them entirely off with their quick disconnect kit installed also. Then just zip tie the sway bar.
Old Oct 18, 2016 | 08:39 PM
lkjk's Avatar
I have TF, a few years old, have rubbed since I got them
Old Oct 19, 2016 | 11:37 AM
resharp001's Avatar
Loved
Community Favorite
Originally Posted by CJ7nvrstk
Luckily, I scored a Currie Antirock for $200 and don't have to worry about it now. Love it!
^^Jealous
I pushed my sway bar up like in jtphoto JK's picture in post #4 the first few times I ever went off road. Didn't take me long to stab a tire. I leave that sway bar parallel to the ground and have had zero issues since. When heading offroad, manually disconnecting is no big deal. The only time it stinks is for that brief impromtu moment when you'd like to be disconnected to flex for a random picture on something, but it's not worth getting out and disconnecting just for that. If I had an Antirock or a simple button to push in the cab, I'd probably be out flexing on various random objects when I saw them....LOL.
Old Oct 20, 2016 | 08:06 AM
MTbjer's Avatar
Default RC link
I have on had them for 2 weeks now but x2 on the Rough Country Sway Bar disconnects, they were almost same cost as longer non-disconnect links and are working well, will see how durable ball joint portion is.
Old Oct 22, 2016 | 10:08 PM
Pats fan's Avatar
Has anyone used the jks flexconnect? It looks cool but pricey.
Old Oct 23, 2016 | 04:27 AM
Canvas's Avatar
Veteran: Navy
I found a Rubi-Sway bar that someone removed and am using that on my Jeep with the EVO No-Limits.
I have also used Rock Kwaler quick disconnects.
R/
Will
Old Oct 23, 2016 | 07:08 AM
jtphoto JK's Avatar
Originally Posted by resharp001
^^Jealous I pushed my sway bar up like in jtphoto JK's picture in post #4 the first few times I ever went off road. Didn't take me long to stab a tire. I leave that sway bar parallel to the ground and have had zero issues since. When heading offroad, manually disconnecting is no big deal. The only time it stinks is for that brief impromtu moment when you'd like to be disconnected to flex for a random picture on something, but it's not worth getting out and disconnecting just for that. If I had an Antirock or a simple button to push in the cab, I'd probably be out flexing on various random objects when I saw them....LOL.
Interesting... what did you stab your tire on. ???
Old Oct 23, 2016 | 09:07 AM
nthinuf's Avatar
With JKS, the mounting post sticks out of the side of the swaybar - pointing right at the tire. So when the links are removed and the swaybar is swung upward, those posts are in a good position to rip the sides out of the tires when they are stuffed/turned.
That's why JKS put a big, bold, notice in the instructions to secure the swaybar down in the neutral position, not swung up.
A lot of people use long zip ties to secure the swaybar in its normal position. I got a pair of nite ize gear ties from home depot, kinda like big rubberized twist ties from a loaf of bread. They work great.
Old Oct 23, 2016 | 03:34 PM
jtphoto JK's Avatar
Ok interesting. With the TF kit there is no post on the stabilizer to stab a tire because the stabilizer link stays attached..
