Quick question, RC x-flex arms!
Old Jan 28, 2013 | 07:04 AM
J3rs3yd3vil's Avatar
Default Quick question, RC x-flex arms!
Alright i've been going back and fourth with these x-flex arms and i am trying to decide if they are the best decision for me at this point. my biggest problem with the arms are the joints, i don't want something that needs to be maintained all the time as this is my daily driver. I wanted to know if any of you have tried swapping the x-flex joint for metal cloaks duroflex joint? if they fit i believe i may keep the arms.
thanks for any info
Old Jan 28, 2013 | 07:27 AM
Pluke the 2's Avatar
just find the thread count and size and buy the shank from one of the many companys.
not a big problem.
Old Jan 28, 2013 | 07:32 AM
havochaos's Avatar
Have you looked into the RK Zero Maintenance arms?
Old Jan 28, 2013 | 10:08 AM
09SDunlimited's Avatar
I had the RC X-Flex arms on my 09. I lubed them well when I first installed them and then everytime I changed the oil. While the oil was draining I lubed them didn't add any extra time. They use a standard zerg fitting and most lube shops should be able to lube them for you if change your oil at one. No issues during the 25000 miles I had them.
