Quick rear trackbar install help please
Old May 13, 2008 | 03:35 PM
davebloomer's Avatar
Default Quick rear trackbar install help please
Just got my lift on and now i can't get my new adjustable trackbar lined up.. i have the upper frame bolt on but it's about 1/2 an inch from being able to get a bolt through the mount on the axle. any help
Old May 13, 2008 | 03:37 PM
Robar's Avatar
Did you try using a ratchet strap to pull the mounts closer together?
Old May 13, 2008 | 03:38 PM
Labrador's Avatar
It's adjustable, so can't you just make it 1/2 inch longer?
Maybe jack the axle up...
no, but that's a great idea and i've got a huge one in my truck from moving
Thanks ROBAR!
G Timmy's Avatar
use a hammer!!!!!!!!
Old May 13, 2008 | 04:25 PM
rvator's Avatar
The rachet strap will work. I used to use a small chain come-a-long to pull my 71 Bronco over to get the front track bar bolted up.
