Raise rear axle brackets
Old Aug 15, 2008 | 10:04 PM
?????'s Avatar
Default Raise rear axle brackets
I'm putting a JK rear axle in a TJ and doing a triangulated 4-link with lower control arm brackets raised to the axle tube height. Everything seemed fine about this until I noticed that the e-brake on the JK axles pulls in towards the center of the diff instead of forward like the TJ rear discs.
The tabs for the e-brake are right where I wanted to mount my lower control arm mounts.
Have any of you done a custom suspension on your JK that raised the lower control arm mounts up or maybe you did some sort of modification to the e-brake brackets that you could post a photo of?
