Ramsey or Mile Marker...
Old Mar 30, 2009 | 01:56 PM
hayden911's Avatar
Question Ramsey or Mile Marker...
I am looking at getting a winch. I have priced a Ramsey with a Winch Mount Plate, in Quadratec (which I assume will bolt on to the factory bumper) or a Mile Marker with a Mounting plate, which says it bolts right up. There is about a hundred dollars difference in the total. Could anyone give some advice? Thanks in advance.
Old Mar 30, 2009 | 02:30 PM
Torrin's Avatar
I believe the Ramsey is made in the USA. If it is that close, get the Ramsey.
Old Mar 30, 2009 | 02:35 PM
Strong Bad's Avatar
I am all about buying made in the USA when possible. If I had gone with an electric winch, I definitely would have bought the Ramsey. Since I went with a Hydraulic, I didn't have much choice. That said I am very pleased with my Mile Marker.
Old Mar 30, 2009 | 03:32 PM
StevieRay's Avatar
Sorry for the hijack, but did you connect the hydraulics up to the stock PS pump?
Old Mar 30, 2009 | 03:40 PM
Rubicon John's Avatar
I'm 99% sure that the Mile Marker hydraulic winches are made in the USA--their electric winches are made in China or somewhere outside of the country.
Old Mar 30, 2009 | 04:03 PM
Strong Bad's Avatar
Yes I did. Works like a champ!!
Old Mar 30, 2009 | 04:04 PM
Strong Bad's Avatar
Even better!!!
Old Mar 30, 2009 | 04:17 PM
mainejeeper's Avatar
are you reffering to the milemarker hydraulic winches or the electric? What model ramsey & milemarker are you looking at? If you list the model numbers, I could help by telling you if they use series wound motors (vs permanent type) and I could compare line pull times. I've got an old issue of JP magazine that lists a winch comparison.
-Nathan
Old Mar 30, 2009 | 05:09 PM
hayden911's Avatar
Both are electric. The mile marker is the SE9500C the reason I was looking at it is because I know I can get a mounting plate that mounts to my factory bumper. The Ramsey is a 8.5e, it is listed in the new Quadratec JK only magazine everyone is talking about on here. It has a price for a Winch Mount, so I assume it mounts directly to the factory as well.
Old Mar 31, 2009 | 02:10 PM
BadTime's Avatar
Had a Ramsey for 13 years on a TJ. It never failed. Pulled at least 1000 times more than any of my friends winches.
