rancho sport kit question
Old May 15, 2009 | 06:55 AM
Rancho's Avatar
Sponsoring Manufacturer
Originally Posted by bigbluejk
At full droop the front driveshaft boot does not hit the skid plate on the auto? What limits it from hitting the skid plate?
No it does not. The shocks are the droop limiter and it stops the axle from drooping far enough for the driveshaft to contact the skidplate. If you upgrade to a larger diameter driveshaft (most aftermarkets are smaller), you may need to notch the skidplate to clearance.
Old May 15, 2009 | 07:03 AM
Rancho's Avatar
Originally Posted by InTheMist
Hm.. Curious. Do you drop the transfer case somehow to correct the angles?
No we do not drop the transfer case on this kit. This is our sport kit which is our first step up from OE. Since the kit reuses OE arms, it does not have the articulation like a full short arm or long arm kit. Our long arm does drop the transfer case to get a better working angle because the amount increased in wheel travel. Since stock was already impressive, our objective for this kit was to maintain OE ride handling, performance, and quality while fitting larger tires on.
Old May 15, 2009 | 07:07 AM
bigbluejk's Avatar
Do those control arm brackets limit travel in any way?
Old May 15, 2009 | 07:14 AM
Rancho's Avatar
No, the bushings in the OE arms are the articulation limiters. Also the shape and design of the brackets mimic the OE control arm brackets. If you added new control arms to the kit you should not have any issues.
Old May 15, 2009 | 07:18 AM
bigbluejk's Avatar
thanks. I just called q-tec about ordering the brackets... If they are within reason money-wise I am adding them to my kit.
Edit: Q-tec just called me back and those things are $130 a pop and on 2-4 week back order... I was going to add those brackets to my current lift kit to make them more parallel to the earth and see if it smoothed out the ride even better than it is. I am not paying that much for an experiment though.
Old May 19, 2009 | 05:28 AM
jkblk's Avatar
how many of you put this kit on yourself, i did the rough county coils on mine so i think i can do it. i just want to know if there is anything i should look out for. also the one who do have did you weld the track bar bracket like the instructions recommend. also you if you have the shock on controller where is a good place to put compressor. thanks
Old May 19, 2009 | 08:44 AM
robin's Avatar
I haven't welded the track bar bracket, when I installed the kit the instructions on mine did not say to do it, but i did think it was a good idea as the bracket is pretty thick, maybe I'll do it soon so far its not a priority. the kit is not that hard to install, pretty much the same as others with the addition of the brackets for the arms, maybe the hardest thing was to cut the screw on the right front arm, but you have to do that with any kit.
Old May 19, 2009 | 08:45 AM
Rancho's Avatar
It's a fairly simple kit to install. If you can do new coils, you should be able to do the entire kit. As long as you have jack stands to support the frame the rest is bolt on. On the weld, you can run it without welding. We offer the weld optional for people who plan to abuse the JK. You can also take it to a fab shop after your done and they can do it without removing anything.
Put the compressor in a high and dry location.
-Rancho
Old May 19, 2009 | 08:47 AM
Rancho's Avatar
Originally Posted by MaloCS
Robin,
Is your front sway bar disconnected in this photo? I have the Rancho Sport on my X Unlimited and I swear I do not get this kind of articulation out of it. Granted, I've never disconnected my front sway bar out of fear of damaging my drive shaft.
Thanks.
Yes, the swaybar limits the front from going full articulation. The kit is designed to allow users to do this and you will not damage the driveshaft.
Old May 19, 2009 | 08:50 AM
robin's Avatar
Robin,
Thanks.
yes it is disconnect it, you would notice a big difference between connected and discoed. try it and see how much more it flexes.
