rancho sport kit question
Old May 26, 2009 | 07:10 AM
  #31
Rancho's Avatar
Sponsoring Manufacturer
Originally Posted by WilliamAWebb
From my understanding, the problem with the axle is not hitting on the automatic transmisson skidplate, rather the auto tranny unit. If you get under the jeep, you will see where the cover bolts together and there is an area where it bolts together where the metal protrudes a little ways. I have 3.5 inch of lift and my driveshafts are no where near hitting the skidplate, but when you are disconnected and your passenger side front wheel droops all the way while your drives side front wheel is pushed up into the fender well, the driveshaft travels up and to the right as the axle moves and this motion causes the boot on the driveshaft to come in contact with the automatic transmission unit. I don't like to disco for this reason. The lowering of the control arms does not address this issue at all, rather it just decreases the need for longer or adjustable control arms. With any lift over 3 inches you are going to run into this problem if you have an automatic tranny. From reading this, it doesn't sound like Rancho has done anything to correct this and I would be tentative to disco and fully droop the passenger side. In my mind the best thing to do is disconnect, droop the right front tire at intervals and look under the jeep to see how close you are to edge of the auto tranny. If you do hit your driveshaft on the auto tranny, you should not only replace your driveshaft, but also check the seal on the auto tranny case to make sure that you are not leaking oil. The driveshaft can actually knock off the edge of the case where the bolt is and this could lead to a leaking problem, which if not fixed could cause a need to replace the whole unit.
We were fully aware of this issue when designing the kit and we would not bring a Jeep kit to market without the expectation of disconnecting swaybar end links offroad. Your comment regarding us overlooking this is as well as any lift over 3 inches will contact is not correct. The bottom line is our kit does not allow the driveshaft to contact the tranny oil pan. We keep some secrets to ourselves regarding all the adjustments we did to achieve this.
Old Oct 7, 2009 | 11:23 AM
  #32
jmontgomery123's Avatar
Default Dear Rancho...
i have the sport kit on my 07 Rubi 4 dr, and have had some problems with Death Wobble. I found out the bolt on's had loosened up and i had them welded. I still have a few issues every now and then but everything is tight underneath. still have a few "shimmy" issues but all geometry is in line as far as alignment is concerned.
I have considered going with your long arm kit, but from what i'm seeing, the lower arms aren't adjustable, and this seams to be the recommendation from all the front end guys i've talked to... (go adjustable arms).
Any help or comments?
