Raptor Liner vs. Duplicolor
Old Jul 21, 2011 | 03:47 PM
EK's JK's Avatar
Default Raptor Liner vs. Duplicolor
Ok, so lining the interior IS going to happen next week. I just need to know what product to buy. I have checked out the duplicolor kit at O'Reilleys and it seems pretty straightforward. Haven't seen the raptor anywhere locally. Which one is better??? Input appreciated.
Old Jul 21, 2011 | 05:13 PM
KyleReikowsky's Avatar
I have used duplicolor in that past and it has always chipped.
Old Jul 21, 2011 | 05:14 PM
Never used raptor liner but I have read good reviews on this forum
Old Jul 21, 2011 | 05:21 PM
Trauma's Avatar
Raptor liner is QUALITY stuff.
Cannot be put on the same level as other do-it-yourself kits. Its the same quality as rhino/line-x
Old Jul 22, 2011 | 04:09 PM
EK's JK's Avatar
Thanks for the info guys. Seems that raptor is the crowd favorite. Does it have a sprayer specific for it? Or can you use any old sprayer? Thanks
Old Jul 22, 2011 | 04:13 PM
Trauma's Avatar
Yep, it comes with a specific spray gun in the kit.
It has a large bore open nozzle. The stuff is very thick. It comes out in a splotchy spray. Needs 60-70 psi.
Old Jul 22, 2011 | 04:28 PM
EK's JK's Avatar
Any ideas on CFM's needed for the gun?
Old Jul 22, 2011 | 04:35 PM
Cpt. Flapjack's Avatar
I used a 6cfm @ 60psi compressor when I did mine. If you look it up on TPtools it gives the specs. The gun you use needs quite a bit of air because the stuff is so thick. You don't want to use one of those little pancake compressors, they won't give you enough volume to get an even spray pattern.
Old Jul 22, 2011 | 04:48 PM
EK's JK's Avatar
I just got a new 25gal compressor that will do 5.8CFM @ 90psi. Should work. How were your results Capn' ?
Old Jul 22, 2011 | 04:56 PM
Great. I have never done any auto spraying before. I just took everything out and taped it off carefully first. The stuff comes out really thick so overspray is easy to avoid. For my 2 door, I sprayed 1 bottle for the first coat, waited an hour, then used a second bottle for the final coat. 4 bottles come with the kit so I still have 2 left if I ever want to do it again. So far after 1 1/2 year it still looks like new. This is the only pic I have:
