Raptor Liner vs. Duplicolor
I actually used 3 bottles on my 2 door, but I put it on THICK! It has been great, wouldn't do it any different. Just a suggestion, while you're at it, re route the tail light wire harnesses through the roll cage padding. It makes for a much cleaner job. Good luck and enjoy.
i think you will be happy. The one thing I did that I wouldn't do again is take out the center console. I have a friend who had his lined and they just taped and plastic covered it and sprayed under the edges. It looks just as good and was a lot easier. I also found that a wire cup brush on a drill worked great for scuffing up the surface before spraying. Quick and easy.
Finished the job today! About 4 hours prep work with an air chisel and a wire cup brush on an angle grinder. About an hour spent on masking it up and another hour spray time (including dry time). And about 30min putting the jeep back together. Super easy, no thinking, just grunt work. This product is amazing! Went on like I knew what I was doing. Couldn't be happier with the result. I'll post some pics tomorrow.
