RCV axle boot
Old Oct 12, 2010 | 04:19 PM
Ryanc's Avatar
Originally Posted by captjay
man u would have to measure a brand new axle c, 20 of us could measure ours now and give back 20 different measurements.
do you have the prosteer ball joints? if not, then i would not worry about the issue. i gusseted mine after nearly 3 years of offroading, so who knows if mine were bent, but i do have the rcv's installed. along with new stock ball joints. if u would like, i will measure what my clearance is, i dont seem to have any issues.
i think it was dave mentioned. you would not want to cut into the boot for the rcv, that would compromise it. the boot holds all the grease in and on extreme turns, the edge of the boot comes close to the edge of the inside of the metal
I have the prosteers. Im just trying to figure out a way to determine if I will have the clearance. Some folks are grinding a little bit of the ball joints, some may not be able to fit even with grinding. Does anyone have the width of the RCV boot at its thickest point, vs the stock rubi u joint?
Old Oct 12, 2010 | 04:45 PM
Dynatrac's Avatar
Sponsoring Manufacturer
Check the clearance between the Rubi u-joint and the RCV boot. If you're anything like the other guys that I've talked to, your measurments will be unequal, side to side.
Old Oct 12, 2010 | 05:26 PM
Ryanc's Avatar
Does anyone have these measurements? My rubi u joint is pretty close as it is right now.
Old Oct 12, 2010 | 05:43 PM
Dynatrac's Avatar
Measure your's to see if they vary side to side.
Old Oct 13, 2010 | 09:02 AM
Ryanc's Avatar
They are about the same, The distance between the U joint is about 4-5mm between the u joint and the balljoint.
Old Oct 13, 2010 | 09:25 AM
Jeep Hound's Avatar
I would love to eventually get these axles, but really dont want to grind on my balljoint. It seems you could trim that boot instead? What do you all think.
I have these axles on my dayna 44 and they dont even come close to the ball joints
Old Oct 13, 2010 | 09:35 AM
Ancient Machine's Avatar
Oh heck, did I need to grind something when I installed these shafts? O_O
Is it the inner arc of the C that is touching the shaft boot that you guys are talking about shaving?
Old Oct 13, 2010 | 10:43 AM
Ryanc's Avatar
The only possible grinding is if you have prosteer balljoints.
Old Oct 13, 2010 | 10:44 AM
Ryanc's Avatar
Do you have the prosteers?
Old Oct 13, 2010 | 03:42 PM
Ryanc's Avatar
My rubi ujoint has about 2-3 mm of clearance from the prosteer ball joint. Does anyone know how much wider the rcv ball is than the rubi u joint.
