Ready for a CHANGE!
Unless yours is broken, save your money. An adjustable front trackbar(to center your axle) would be a good start. You shouldn't have to worry about driveshafts with a 6 speed unlimited(at least not for awhile).
Edit: Also, 4.88's will work great with 35's and a 6 speed, but if's there's a decent chance you'll move up to 37's, give a good look at the 5.13's. It really depends on how much you travel on the interstate. If you consistently run 70-80, 5.13's might be a bit steep even with 37's.
Thanks!
Definitely will be looking into a tire carrier as well. Any recommendations?
as an example...
manual, 5.13's, 34" actual height tires
= close to 3k rpm at 70 mph
A lot of people might think that is too high...
There are some great RPM charts in the Drivetrain FAQ's. (use actual tire heights, not mfg's specs). They are much more accurate than getting advice from people who either don't own a JK, or own a JK but it is a different transmission than yours.
as an example...
as an example...
