Rear axle breather hose routing?
Old Mar 20, 2016 | 10:15 AM
busa250's Avatar
Default Rear axle breather hose routing?
Y rear breather hose is hitting my heat shield. O had a shop install my lift so i do not know how it should be routed. I have a 3" lift. Does it need a longer hose to be routed the right way? It is on a 16' hard rock rubi. Pics would help!! Right now it comes off the axle towards the back under the crossmember then back towards the from the mount on the inside of fender rivet. Thanks in advance for your help!!
Old Mar 20, 2016 | 01:48 PM
14Sport's Avatar
I have a 2.5" lift which netted 3.25" in the rear. I extended my line and ran it this way.
Name:	RearAxleBreather 01 (Medium).JPG
ID:	641234   Click image for larger version
Name:	RearAxleBreather 02 (Medium).JPG
ID:	641235   Click image for larger version
Name:	RearAxleBreather 03 (Medium).JPG
Old Mar 20, 2016 | 01:57 PM
karls10jk's Avatar
14Sport has it set up well, I took it a step further and went into the taillight cavity. If I'm that deep in water then I've got bigger problems. His routing also avoids the heat shield.
Old Mar 20, 2016 | 02:44 PM
busa250's Avatar
Great pictures. Thank you!!
Old Mar 20, 2016 | 02:57 PM
14Sport's Avatar
You're welcome.
Old Mar 20, 2016 | 06:18 PM
NJKURPat's Avatar
Routed up behind the rear passenger tail light.
Old Mar 20, 2016 | 07:24 PM
Chuck-The-Ripper's Avatar
I routed mine into where the jack goes.
Old Mar 21, 2016 | 04:54 AM
dcm80401's Avatar
That will fill up with water . Had mine do that in a rain storm going topless.
Old Mar 21, 2016 | 06:11 AM
Thanks for the advice, but I routed it up in and then looped the end so that the opening faces down. I don't see any trouble with that, do you?
Old Mar 21, 2016 | 01:48 PM
Cat Dr.'s Avatar
Default Breather routing
I have a 2008 2 door, I routed mine up into the drivers side rear tail light compartment. As stated above, if the water gets that high I have far greater problems.
