Rear axle leaking need help!
Old May 22, 2012 | 09:30 AM
Justinn407's Avatar
Default Rear axle leaking need help!
Need a second opinion.. I have a rear non rubi 44 leaking (d/s) I've found that the bearing has some play in it and will prob have to be replaced soon. What I can't figure out is if I should just get a new bearing kit and hope labor to disassemble and remove and press new ones in will be a smart move of if I should just go ahead and replace te shafts/ bearings all together. I can get ten shafts with everything pressed and ready to roll from northridge4x4 for about 300 more that just the bearing kit. I guess what I'm worried about is the labor cost to replace bearings on stock axles will amount to the new ones I can get and just install myself. Someone please direct my decision, also any input on the "ten" shafts appreciated...
Old May 22, 2012 | 10:06 AM
meatsandwich's Avatar
Rear axleshaft bearings usually don't just go bad without cause. Your axleshafts/ flanges may be bent. I'd keep driving it until you can replace the axleshaft assemblies all at once. I don't know if Ten's kit comes with the outer bearing retainers($25 ea), and you may want to get those from Mopar first. $300 to press on the stack-up sounds about $200 too high. I pressed mine myself in 15 minutes , but was quoted $100 for both shafts at the dealer.
