Rear axle not centered with re-location bracket
Old Jan 15, 2012 | 08:16 PM
Trauma's Avatar
Default Rear axle not centered with re-location bracket
I have a rockkrawler stock mod kit, 2.5" lift.
front/rear springs
front trackbar
rear relocation bracket.
The rear axle, is off to the left by 1" Why is this?
It isn't noticeable but I am looking to get bigger tires soon (currently stock) and im sure the difference will become more apparant.
Old Jan 15, 2012 | 08:24 PM
RodCyn's Avatar
Due to how the Jeep's trackbars (front and rear) are configured, when you lift your Jeep, the front axle tends to move toward drivers side and the rear tends to move toward the passenger side. That being said, the replacement rear drop bracket is supposed to move your axle back toward the drivers side.
It seems, by your description, that you did not get a high enough lift to make a big difference, thus your axle was pushed too far back toward the drivers side, when corrected by the new bracket. It really should not make any significant difference on the way it handles or rides, but there are a couple of things you may want to consider. Remove the bracket and put the trackbar back in it's original position and see what how your axles are, or get an adjustible trackbar so you can fine tune the trackbar length, thus centering your axle.
Old Jan 15, 2012 | 09:39 PM
nthinuf's Avatar
Or add more lift...
Old Jan 16, 2012 | 04:57 AM
F200's Avatar
Anyone know which adj. trackbars will go shorter than stock? I have the same thing. CM
Old Jan 16, 2012 | 06:28 AM
Rock Krawler Suspension's Avatar
Former Vendor
Did you weld the mount on already? If not, just make sure it is square first. If the bracket is rotated just a little bit, it will throw the rear axle off a good amount since the bracket is canted!
RK
Old Jan 17, 2012 | 04:30 AM
Trauma's Avatar
RK
Na i never welded it, but it is definitely on straight.
Old Jan 17, 2012 | 06:16 AM
wayoflife's Avatar
JK-Forum Founder
as mentioned, it sounds as if you didn't get as much lift as the bracket was designed for as it clearly over corrected the position of your axle.
Old Jan 17, 2012 | 06:22 AM
Rockroaster's Avatar
X2. I had this issue with mine when my coils started to drastically sag. Installed new, better coils, which raised me back up, and now its back to center
