Rear Axle shafts seized
#25
Claw hammers are for wood work, framing, that kind of stuff, not for Jeeps.
You need a BFH to help in your situation, not a claw hammer. It's all about having the right tool for the job.
#26
I have a BFH it doesn't work ether, I have a slide hammer, it doesn't work, I used the claw to create pressure on the lug plate of the axle while my buddy beat the slide hammer or BFH on the axle itself. Nothing
#27
You need a good stout bar, minimum 4' long. We fought with mine for over 4 hours until we did the prybar slidehammer trick .. that seal was really stuck in there. ... I even tried a 10' length of 1" chain .. flick the chain like a whip and the weight of the chain works like a slidehammer. Even that did not work.
#28
Go to the junk yard and get a scrap 5x5 rotor to use and beat on it.
A buddy of mine chained his housing to a tree, wrapped another chain around the axle, and attached that to a backhoe and yanked on it. Hopefully you won't have to resort to such drastic measures. I feel fortunate that mine came out like butter with the slide hammer.
#30
Mine was just the seal stuck in the end of the tube. You could see the seal flex when prying on it but it would just not let go. I attributed the tight seals to years of road salt and at one point both of my rear calipers had seized and overheated the rear brakes.
