Rear Driveshaft CV Problem
Old 12-19-2007, 07:38 PM
Old_School's Avatar
Default Rear Driveshaft CV Problem
I just blew up my rear driveshaft CV. It started out as a small vibration and ended up with grinding and oil thrown out around the CV joint. The Jeep has 5400 miles and a 3" lift. I guess it is time for a Reel driveline.
Old 12-19-2007, 07:41 PM
Piginajeep's Avatar
yep mine did the same, around that mileage, Time to give Northridge a call!
Old 12-22-2007, 06:06 AM
Old_School's Avatar
I am surprised this is not happening to more jeeps with a 3" lift. The front CV on the rear axle is at max angle particularly with the Teraflex lift which is more like 4".
I order a new driveshaft from David at Northridge. Hopefully it will be here right after Christmas.
Old 12-22-2007, 06:54 AM
stumpman79's Avatar
Default J.E. Reel Driveshafts
I have a 2DR Rubicon JK and ive had the 1350 Heavy Duty JE Reel Front and Rear driveshafts on my Jeep for 21,000 miles (11 months) with no problems. Considering I drive like a mad man and im running 37's... I'd say thats great. They are alitlle pricey but i think they were worth every cent.
Old 12-22-2007, 07:25 AM
RUBICONPOOR's Avatar
Do you have the adjustable control arms? I have the same lift but with upper and lower adjustable arms and the pinion angle set at 1 degree. I was wondering if I will be having this issue soon.
Old 12-22-2007, 07:39 AM
SLICKWILL's Avatar
im on 6" of lift with stock shafts.....they cry as i drive down the road......when i was on 4" they were great
Old 12-22-2007, 07:42 AM
VBS4's Avatar
Since Reel is a site sponsor, give them a call directly.
I just checked on a front driveshaft (just in case) and they're cheaper to buy directly from.
http://www.reeldriveline.com/
Old 12-22-2007, 08:02 AM
Old_School's Avatar
I ordered a new Reel driveshaft a few days ago.
Old 12-22-2007, 08:07 AM
VBS4's Avatar
Did you buy the OE replacement one or the one that comes with replacement yokes
Old 12-26-2007, 03:34 PM
Old_School's Avatar
I bought the OE replacement. I am not a serious rock crawler so it should be sufficient for my needs.
Quick Reply: Rear Driveshaft CV Problem
