2008 JKUR Rear Wheel Chirp/Squeak
Driving into work this morning with the top off and I noticed I have a pretty bad rotational chirp/squeak coming from the rear, my ear says right rear wheel, definitely speed dependent, seemed to go away/lessen while coasting in neutral/with the clutch depressed and also while braking.
Mostly wondering if there's a likely culprit...do the wheel bearings get noisy in this fashion when they need replaced? Maybe brake/caliper dragging? Debating if I need to run it to a local shop before I head home today or if it can wait
That was my first guess, a little perplexed why it goes away when I am coasting in neutral/clutch in though going away while braking makes sense....I'll get it up on a jack tonight when I get home and see if there's any obvious signs of a wobble.
