Rear location bracket question
Old Feb 18, 2019 | 08:50 PM
VitalJeep's Avatar
Default Rear location bracket question
Good evening...
I recently installed a 2.5” Rubicon Express suspension lift which came with a rear track bar relocation bracket.
I also installed adjustable lower control arms and an adjustable front track bar.
After installing a rear AEV tire carrier, front bumper stinger, winch mounting plate, and winch, I’ve lost a little height.
I was thinking of adding 1” coil spacers to regain some height and get a little extra.
Should I be ok to add these coil spacers with that relocation bracket? I’m thinking I’ll be sitting at about 3” after the 2.5” lift, 1” coil spacers, and sag from the added weight. The bracket was made for 2.5”
Please share your thoughts!
Old Feb 18, 2019 | 09:57 PM
nthinuf's Avatar
The rear bracket will be fine, it's a fractional difference. I haven't actually seen anyone post a table that shows 1" lift height = 1/8" or 1/16" axle shift or whatever, but the change you are talking about will be minimal. Ya know, started at 2.5", lost .5" from weight, add 1" spacers, nets you out .5" taller than the you started, with the axle shifted another 1/16" or whatever (no idea of the real measurements, just throwing random numbers at it). If you are super anal and have to have that axle perfectly centered, add an adjustable trackbar later...
Old Feb 21, 2019 | 11:24 AM
resharp001's Avatar
Loved
Community Favorite
If it makes you feel any better, I have a raised bracket and an adjustable rear TB......and I intentionally cheat my axle off center to the driver's side. if I don't, I have clearance issues with my DS yoke hitting my gas skid when wheeling. It won't be a big deal at all. If it bothers you enough, I think the cheapest adjustable rear TB out there is still probably the Rough Country one. I'm not a fan of RC products, but that is what I actually have on mine. The rear TB is just not that important relative to all other suspension parts. It's just centering the axle.
Old Feb 28, 2019 | 02:30 PM
VitalJeep's Avatar
Default Thank you, both!
Thanks, guys. I ordered the coil spacers today. I also ordered some brake line relocation brackets for good “measure”... hehe
Old Mar 1, 2019 | 06:18 AM
resharp001's Avatar
Loved
Community Favorite
While you're back there by the brake lines, it's often handy to take a big zip tie and pull the hard brake lines as snug to the frame rail as possible. This depends on what links you have and how you have bolts orientated, but a common problem is that the sway bar passes up above the brake line when wheelin, and then when it comes back to a neutral position the sway bar link's bolt grabs the hard brake line and pulls it down in to a "V". I can tell you from experience, it's easier to secure that hard brake line with nice thick zip ties than it is to replace those hard lines. Peace of mind. You can get nice thick zip ties at WalMart for cheap....18"+ lengths in 5-6 packs for a couple bucks.
Old Mar 1, 2019 | 06:09 PM
VitalJeep's Avatar
thank you! I’ll take a look.
i did also buy a set of JKS brake line relocation brackets. I know you’re not referring to the lines in that area, but I just thought I’d throw that out there.
im open to any little tidbits of knowledge!
Old Mar 2, 2019 | 01:41 PM
resharp001's Avatar
Loved
Community Favorite
quick snapshot -
Nothing fancy. With a drop bracket, you're pulling that hard line just a touch lower as well (more in to harms way). Quick zip tie does help a bit.....better than nothing at least. Notice I don't have a big zip tie like I suggested above, just a couple normal ones. I need to replace mine with a good tie that I now have on hand.
Old Mar 2, 2019 | 03:52 PM
VitalJeep's Avatar
quick snapshot -
thank you! 👌🏼
