rear shock rub
I've got a 2 door rubicon with a 4'' pro comp lift, adj upper control arms, with the pinion turned up with a double cardon DL. i noticed when adjusting the pinion angle, the rear driver side shock is slightly rubbing on the rear sway bar mount just enough to cut the rubber boot and scratch the shock tube. is this something i can replace/ adjust?
i wish i had a picture. the monotube shock is inverted an the upper portion of the rubber boot rubs on the AM bracket which is bolted to the stock sway bar mount welded to the axle tube:confused:
