rear spring guide - top mount
Old Oct 5, 2009 | 07:13 AM
Ramphog's Avatar
Default rear spring guide - top mount
I finally decided to get rid of the TF Budget boost... nothing wrong with it.... Love the TF products, just replaced the BB and installed some actuall 2.5 inch TF springs......
Looks like I might have gained an inch.....
so thats cool
Issue is now I dont have the drop down guide to keep my springs in line. I did buy the JKS spring retainers for the bottom... PIA to install but they do work.....
Question is this....
I am pondering ordering these from TF...
http://www.teraflex.biz/products/jk-...ndividual.html
Never will be against their products.... but .. with a slimmer budget these days... is there another alternative? Or is TF the only way to go.......
Again.. nothing against TF.... they have been very good so far... just looking to save a buck......
Anyone else using anything else?
Thanks if ya can help...........
Old Oct 5, 2009 | 07:20 AM
TeraFlex's Avatar
Sponsoring Manufacturer
No problem. I can understand trying to save a buck or two. Hmmm, I might have a pair that were returned.........
Old Oct 5, 2009 | 07:22 AM
Ramphog's Avatar
Well hook a brutha up!
lol
PM Sent....
Old Oct 5, 2009 | 07:49 AM
Ramphog's Avatar
Thanks for the post and idea... but just bought bottom retainers.. so only need the top......
But will keep it in mind..... can always pull off the bottom mounts i just put on and resell them....
Or return them for being a PIA.. lol
Old Oct 5, 2009 | 07:57 AM
nthinuf's Avatar
You gained an inch in height from the coils, but are using the same shocks? Over-extending and dropping a coil should be prevented by the shorter shocks now, shouldn't it?
Old Oct 5, 2009 | 08:10 AM
HG07JKRubi's Avatar
x2...if you're using the same shocks you don't need those top spacers/retainers. And if you went from a 2.5" TF BB to a 2.5" TF coils you actually lost .5" in the rear as the rear coils provide 2" of lift. Still though, if you're using the same shocks (or factory shocks with extensions) you don't need the spacer/retainer. They are only needed if you go to a longer rear shock like the TF 9550's
Old Oct 5, 2009 | 08:14 AM
TeraFlex's Avatar
Unless he has the TeraFlex one's.
Ramphog's Avatar
Since Install I have been using Rubi shocks with the extenders... guess I should have added that.... New shocks will be coming after tho... so yea... will need something
Old Oct 6, 2009 | 07:13 AM
Ramphog's Avatar
Thanks Joe!!!!! You're the man!!!!!!!!!
