Rear spring relocation brackets??
Old Jan 3, 2008 | 08:08 AM
RUBICONPOOR's Avatar
Default Rear spring relocation brackets??
I had a 04 TJ Rubi with the Nth degree lift prior to buying the JK, with the lift kit it had rear spring brackets for the upper perch(so that the spring would not be bowed forward when you rotate your axle.) I was wondering if anyone has seen a product like that for the JK.
Old Jan 3, 2008 | 02:55 PM
jkdwindeck's Avatar
I believe AEV has bought out Nth degree. They are in the process of doing some reengineering of the kit. You may be able to call for an update.
Old Jan 3, 2008 | 03:49 PM
I called John at AEV and he said there will be a lift kit available this spring, but he has not heard of any plans for relocating the rear springs like they did for the TJ. I need to get this fixed since I rotated the axle back the springs are bowing quite a bit.
