Rear tow hook.
I bought this rear tow hook for my 07 JK that has three holes in it. When I was trying to install it on the rear frame, it looks off a little bit to the side. Is it not supposed to be in the center of the rear bumper where that little notch is at or is it fine?
And to install it do I need to take the rear bumper off or can I just put it from below? Thanks.
'07s and '08s had them mounted in the center where the hitch would be mounted. If you bought the Mopar accessory then it would be the earlier center mounted version
this is it exactly. the center of the curve of the hook should just about line up with the little indent on the bumper. u would want to use the right 3 of the 4 holes on the crossbar. the mounting portion looks off-centered but the hook itself should just about be centered
