Rear track bar bracket?
Old Jul 7, 2012 | 06:28 PM
GunDude's Avatar
Default Rear track bar bracket?
Will be rotating the rear axle to correct the pinion angle when I put in a Coast DS. Been reading, that this will put a lot of strain on the rear axle side track bar mount. I also have a JKS adj. rear track bar. Was just wondering if this is something I should address, with a JKS rear adj. track bar bracket?
Old Jul 7, 2012 | 07:58 PM
k0260's Avatar
I've heard the stock axle side of the track bar mount is prone to breaking/failing mainly from extreme articulation and hard off road use. Another option is Tera Flex's HD bracket, mounts to stock mount and around the axle for a strong set up cutting out the weak link of the stock mount, very happy with mine
Old Jul 7, 2012 | 08:31 PM
Ratischh's Avatar
Do you need a relocation bracket when using jks adjustable trackbar?
