rear track bar relocation?
Old Sep 16, 2011 | 07:17 PM
saravonshep's Avatar
Originally Posted by fab1
this is what i'm trying to do but will this work with the JKS braces I aready have welded on my axle
Im pretty sure this will not work with the JKS brace, all though i could be wrong. Ill be watching for the pros to respond.
Old Sep 16, 2011 | 07:21 PM
road_king's Avatar
The JKS rear trackbar relocation bracket works with the JKS adjustable trackbar and the weld on FAB piece ----according to JKS.
Old Sep 16, 2011 | 09:18 PM
MOKOS's Avatar
Yeah I called up JKS back when I first started this thread and they were just about to release a relo bracket that works with the welded on brace. They sold it to me before it was officially up for sale. It's great and works with my JKS rear spring mounts too. It's on their site now.
Old Sep 16, 2011 | 09:19 PM
MOKOS's Avatar
Originally Posted by Andrew@EVOMFG
As many have shown, you can get away without a bracket, but Trackbar brackets are very benefical on many levels.
First: Assuming stock mounting locations. The more you lift the JK the steeper the angle of the trackbar gets from horizontal. The steeper this is the more your axle will shift from left to right as your suspension moves up and down over bumps. This shift is minimized greatly the closer the Tbar gets to horizontal. When the axle shifts during the suspension cycle is what primarly leads to the feeling the Jeep can have of wiggling around like a boat.
Second: By raising the Tbar at the axle, (not lowering at the frame, this has opposite effect) you are altering what is called roll center closer to what it was when the JK was stock. Roll center is the major factor on how much the JK leans into a turn. The better the roll center (raising the trackbar mount at the axle) the better the JK will turn at speed (less roll).
Third: The JKs Tbar mounts on the axles are know to be weak and break off, so bracing them with an aftermarket bracket (and one that helps the other two areas) is a good idea.
EVO...
http://www.offroadevolution.com/stor...d=EVO-REAR-RCC
Great info! Thanks for helping me further understand all of this.
Old Sep 17, 2011 | 04:25 AM
fab1's Avatar
Can you post any pic of it installed. I saw that relocate bracket last night and thought that would be the way to go and did you just bolt it on or put a few weld on also?
Old Sep 17, 2011 | 06:49 AM
road_king's Avatar
Did you have to re-adjust your track bar when you added the relocation bracket? I have your same setup and am considering the new bracket. Thanks
Old Sep 17, 2011 | 10:01 AM
jimk403's Avatar
What amount of lift is the EVO bracket designed to work with?
Old Sep 17, 2011 | 04:19 PM
MOKOS's Avatar
Yeah, anytime you change something like that it will need subtle adjustment. U just shorten it a bit.
Old Sep 17, 2011 | 05:09 PM
This sounds great, i will look into this.
Old Sep 19, 2011 | 12:53 PM
Andrew@EVOMFG's Avatar
Sponsoring Manufacturer
EVO MFG Representative
The EVO RCC is designed for 3"+ of lift (actual rear lift increase, no the label on the side of the box).
